# Jetpack 3.1 Example ( Tegra Multimedia API ) gets failed
**URL:** <https://forums.developer.nvidia.com/t/jetpack-3-1-example-tegra-multimedia-api-gets-failed/55314>\
**Category:** Jetson TX2\
**Created:** [November 17, 2017, 5:06am UTC](https://forums.developer.nvidia.com/t/jetpack-3-1-example-tegra-multimedia-api-gets-failed/55314 "2017-11-17T05:06:33Z")\
**Posts on this page:** 6\
**Page:** 1
<div class="post-metadata">
**Author:** ![BalajiNP](https://developer.download.nvidia.com/images/forums/profile-default-devtalk-84.png) [@BalajiNP](https://forums.developer.nvidia.com/u/BalajiNP)\
**Post date:** [November 17, 2017, 5:06am UTC](https://forums.developer.nvidia.com/t/jetpack-3-1-example-tegra-multimedia-api-gets-failed/55314/1 "2017-11-17T05:06:33Z")
</div>
Tried the jetpack 3.1 examples in HDMI2CSI device and got the errors as:
nvidia@tegra-ubuntu:~/tegra\_multimedia\_api/samples/10\_camera\_recording$ ./camera\_recording -t H265 -d 30
Set governor to performance before enabling profiler
NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
NvPclHwGetModuleList: No module data found
PCLHW\_DTParser
PCLHW\_DTParser
LoadOverridesFile: looking for override file [/Calib/camera\_override.isp] 1/16LoadOverridesFile: looking for override file [/data/nvcam/settings/camera\_overrides.isp] 2/16LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/camera\_overrides.isp] 3/16LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/camera\_overrides.isp] 4/16LoadOverridesFile: looking for override file [/data/nvcam/camera\_overrides.isp] 5/16LoadOverridesFile: looking for override file [/data/nvcam/settings/tc358840\_rear\_1700.isp] 6/16LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/tc358840\_rear\_1700.isp] 7/16LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/tc358840\_rear\_1700.isp] 8/16---- imager: No override file found. ----
checkDriverVersion: Mixed or missing V4L2 controls!
checkDriverVersion: Make sure your kernel driver implements either
checkDriverVersion: V4L2\_m\_cidFrameLength + V4L2\_m\_cidCoarseTime(\_SHORT)
checkDriverVersion: or
checkDriverVersion: V4L2\_m\_cidFrameRate + V4L2\_m\_cidExposure
(NvOdmDevice) Error BadParameter: (in dvs/git/dirty/git-master\_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function checkDriverVersion(), line 379)
(NvOdmDevice) Error BadParameter: (propagating from dvs/git/dirty/git-master\_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function findCustomCids(), line 309)
(NvOdmDevice) Error BadParameter: (propagating from dvs/git/dirty/git-master\_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function initializeV4L2Items(), line 232)
(NvOdmDevice) Error BadParameter: (propagating from dvs/git/dirty/git-master\_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function initialize(), line 107)
NvPclDriverInitializeData: Unable to initialize driver v4l2\_sensor
NvPclInitializeDrivers: error: Failed to init camera sub module v4l2\_sensor
NvPclStartPlatformDrivers: Failed to start module drivers
NvPclStateControllerOpen: Failed ImagerGUID 1. (error 0x4)
NvPclOpen: PCL Open Failed. Error: 0xf
SCF: Error BadParameter: Sensor could not be opened. (in src/services/capture/CaptureServiceDeviceSensor.cpp, function getSourceFromGuid(), line 596)
SCF: Error BadParameter: (propagating from src/services/capture/CaptureService.cpp, function addSourceByGuid(), line 781)
SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function addSourceByIndex(), line 276)
SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function getSource(), line 439)
(Argus) Error BadParameter: (propagating from src/api/CameraProviderImpl.cpp, function initialize(), line 92)
(Argus) Error BadParameter: (propagating from src/api/GlobalProcessState.cpp, function createCameraProvider(), line 214)
Error generated. main.cpp, execute:408 Failed to create CameraProvider
-Thanks.
**Author:** ![DaneLLL](https://sea2.discourse-cdn.com/nvidia/user_avatar/forums.developer.nvidia.com/danelll/32/14043_2.png) [@DaneLLL](https://forums.developer.nvidia.com/u/DaneLLL)\
**Post date:** [November 17, 2017, 6:39am UTC](https://forums.developer.nvidia.com/t/jetpack-3-1-example-tegra-multimedia-api-gets-failed/55314/2 "2017-11-17T06:39:44Z")
</div>
Hi BalajiNP,
The sample is for bayer sensors using TX2 ISP engine. Yours looks to be an v4l2src. You may try 12\_camera\_v4l2\_cuda
**Post date:** [November 17, 2017, 11:02am UTC](https://forums.developer.nvidia.com/t/jetpack-3-1-example-tegra-multimedia-api-gets-failed/55314/3 "2017-11-17T11:02:56Z")
</div>
Hi DaneLLL,
12\_camera\_v4l2\_cuda example is working fine in this board.
-Thanks.
**Post date:** [November 18, 2017, 4:47am UTC](https://forums.developer.nvidia.com/t/jetpack-3-1-example-tegra-multimedia-api-gets-failed/55314/4 "2017-11-18T04:47:35Z")
</div>
Hi DaneLLL,
In jetpack 3.1, in tegra\_multimedia\_api directory, what are the examples belongs to UYVY video format or V4L2src. How to find out in source code which belongs to bayer sensors and which belongs to v4l2src.
Please provide the proper documentation link for this information.
-Thanks.
**Post date:** [November 20, 2017, 2:01am UTC](https://forums.developer.nvidia.com/t/jetpack-3-1-example-tegra-multimedia-api-gets-failed/55314/5 "2017-11-20T02:01:00Z")
</div>
Hi BalajiNP,
Documentation of tegra\_multimedia\_api is in [https://developer.nvidia.com/embedded/dlc/l4t-documentation-28-1](https://developer.nvidia.com/embedded/dlc/l4t-documentation-28-1)
**Author:** ![nadeemm](https://sea2.discourse-cdn.com/nvidia/user_avatar/forums.developer.nvidia.com/nadeemm/32/367020_2.png) [@nadeemm](https://forums.developer.nvidia.com/u/nadeemm)\
**Post date:** [October 18, 2021, 6:27pm UTC](https://forums.developer.nvidia.com/t/jetpack-3-1-example-tegra-multimedia-api-gets-failed/55314/6 "2021-10-18T18:27:26Z")
</div>
Closed on October 18, 2021, 6:27pm UTC
