this is the demesg --follow
but the /dev/rfkill still missing.
[ 7.349186] tegra-pcie 1003000.pcie-controller: link 1 down, retrying
[ 7.444748] systemd-journald[225]: Received request to flush runtime journal from PID 1
[ 7.658791] xhci-tegra 70090000.xusb: cannot find firmware....retry after 1 second
[ 7.763264] tegra-pcie 1003000.pcie-controller: link 1 down, retrying
[ 7.773929] random: nonblocking pool is initialized
[ 7.778643] tegra-pcie 1003000.pcie-controller: link 1 down, ignoring
[ 7.778665] tegra-pcie 1003000.pcie-controller: PCIE: no end points detected
[ 7.779697] tegra-pcie 1003000.pcie-controller: PCIE: Disable power rails
[ 7.897559] dhd_module_init in
[ 7.903521] found wifi platform device bcmdhd_wlan
[ 7.922796] Power-up adapter 'DHD generic adapter'
[ 7.937006] wifi_platform_set_power = 1
[ 8.147251] wifi_platform_bus_enumerate device present 1
[ 8.171475] wifi_platform_bus_enumerate device present 0
[ 8.182037] F1 signature read @0x18000000=0x17214354
[ 8.193260] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 8.202227] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 8.211178] wifi_platform_prealloc: failed to alloc static mem section 7
[ 8.219932] wifi_platform_get_mac_addr
[ 8.230585] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[ 8.239944] wl_create_event_handler(): thread:wl_event_handler:1f5 started
[ 8.239951] CFG80211-ERROR) wl_event_handler : tsk Enter, tsk = 0xffffffc0f2281a70
[ 8.258365] dhd_attach(): thread:dhd_watchdog_thread:1f8 started
[ 8.258395] dhd_attach(): thread:dhd_dpc:1f9 started
[ 8.258425] dhd_attach(): thread:dhd_rxf:1fa started
[ 8.258430] dhd_deferred_work_init: work queue initialized
[ 8.258659] Dongle Host Driver, version 1.201.82 (r)
Compiled in drivers/net/wireless/bcmdhd on Aug 12 2017 at 22:08:49
[ 8.259250] tegra_sysfs_register
[ 8.259287] Register interface [wlan0] MAC: 00:04:4b:58:30:2a
[ 8.259290] dhd_prot_ioctl : bus is down. we have nothing to do
[ 8.259386] sdhci-tegra sdhci-tegra.1: Tuning already done, restoring the best tap value : 77
[ 8.260429] wifi_platform_set_power = 0
[ 8.666320] xhci-tegra 70090000.xusb: Firmware timestamp: 2016-11-24 02:31:08 UTC, Version: 50.18 release
[ 8.668358] xhci-tegra 70090000.xusb: xHCI Host Controller
[ 8.668376] xhci-tegra 70090000.xusb: new USB bus registered, assigned bus number 1
[ 8.669214] xhci-tegra 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00010810
[ 8.669240] xhci-tegra 70090000.xusb: irq 319, io mem 0x70090000
[ 8.669358] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 8.669361] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.669364] usb usb1: Product: xHCI Host Controller
[ 8.669366] usb usb1: Manufacturer: Linux 4.4.38-tegra xhci-hcd
[ 8.669368] usb usb1: SerialNumber: 70090000.xusb
[ 8.669910] hub 1-0:1.0: USB hub found
[ 8.670052] hub 1-0:1.0: 5 ports detected
[ 8.687276] xhci-tegra 70090000.xusb: xHCI Host Controller
[ 8.687286] xhci-tegra 70090000.xusb: new USB bus registered, assigned bus number 2
[ 8.687422] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 8.687426] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.687428] usb usb2: Product: xHCI Host Controller
[ 8.687430] usb usb2: Manufacturer: Linux 4.4.38-tegra xhci-hcd
[ 8.687432] usb usb2: SerialNumber: 70090000.xusb
[ 8.688785] hub 2-0:1.0: USB hub found
[ 8.688950] hub 2-0:1.0: 4 ports detected
[ 8.810728] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 8.810993]
[ 8.810996] wl_android_wifi_on in
[ 8.811000] wifi_platform_set_power = 1
[ 8.999802] usb 2-1: new SuperSpeed USB device number 2 using xhci-tegra
[ 9.025788] usb 2-1: New USB device found, idVendor=0955, idProduct=09ff
[ 9.032566] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[ 9.039904] usb 2-1: Product: USB 10/100/1000 LAN
[ 9.044776] usb 2-1: Manufacturer: Nvidia
[ 9.056242] usb 2-1: SerialNumber: 000001000000
[ 9.062707] xhci-tegra 70090000.xusb: tegra_xhci_mbox_work mailbox command 6
[ 9.072494] xhci-tegra 70090000.xusb: tegra_xhci_mbox_work mailbox command 6
[ 9.080031] xhci-tegra 70090000.xusb: tegra_xhci_mbox_work mailbox command 6
[ 9.097472] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 9.169541] sdhci-tegra sdhci-tegra.1: Tuning already done, restoring the best tap value : 77
[ 9.169898] F1 signature read @0x18000000=0x17214354
[ 9.173147] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 9.173596] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 9.200188] usb 2-1: reset SuperSpeed USB device number 2 using xhci-tegra
[ 9.220668] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 9.262014] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 9.263170] wifi_platform_get_mac_addr
[ 9.264584] Firmware up: op_mode=0x0005, MAC=00:04:4b:58:30:2a
[ 9.269902] dhd_preinit_ioctls pspretend_threshold for HostAPD failed -23
[ 9.274213] Firmware version = wl0: Sep 14 2016 11:38:27 version 7.35.221.18 (r657725) FWID 01-9001dfb5
[ 9.276450] dhd_interworking_enable: failed to set WNM info, ret=-23
[ 9.276618] tegra_sysfs_on
[ 9.331624] r8152 2-1:1.0 eth0: v2.03.3 (2015/01/29)
[ 9.331627] r8152 2-1:1.0 eth0: This product is covered by one or more of the following patents:
US6,570,884, US6,115,776, and US6,327,625.
[ 9.399162] tegradc tegradc.1: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 9.400067] tegradc tegradc.1: hdmi: pclk:148500K, set prod-setting:prod_c_hdmi_75m_150m
[ 9.492158] CFGP2P-ERROR) wl_cfgp2p_add_p2p_disc_if : P2P interface registered
[ 9.511109] WLC_E_IF: NO_IF set, event Ignored
[ 9.769077] tegradc tegradc.1: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 9.771022] tegradc tegradc.1: hdmi: pclk:148500K, set prod-setting:prod_c_hdmi_75m_150m
[ 9.891929] cfg80211: World regulatory domain updated:
[ 9.897093] cfg80211: DFS Master region: unset
[ 9.901522] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 9.915467] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 9.923559] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 9.923561] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 9.923564] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 9.923567] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 9.923569] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 9.923571] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 9.923572] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 10.112319] tegradc tegradc.1: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 10.113139] tegradc tegradc.1: hdmi: pclk:148500K, set prod-setting:prod_c_hdmi_75m_150m
[ 10.417779] r8152 2-1:1.0 enx00044b58302c: renamed from eth0
[ 10.449721] IPv6: ADDRCONF(NETDEV_UP): enx00044b58302c: link is not ready
[ 10.535441] IPv6: ADDRCONF(NETDEV_UP): enx00044b58302c: link is not ready
[ 12.735715] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 12.753858] Bluetooth: BNEP socket layer initialized
[ 13.019343] IPv6: ADDRCONF(NETDEV_CHANGE): enx00044b58302c: link becomes ready
[ 13.109793] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[ 13.143144] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[ 13.166799] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[ 13.168558] tegradc tegradc.1: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 13.169386] tegradc tegradc.1: hdmi: pclk:148500K, set prod-setting:prod_c_hdmi_75m_150m
[ 13.198620] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[ 13.200868] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[ 13.203923] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[ 13.226042] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[ 13.228348] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[ 13.241652] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[ 13.278162] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[ 195.861874] Bluetooth: RFCOMM socket layer initialized
[ 195.867370] Bluetooth: RFCOMM ver 1.11
