JetPack 3.2.1 and TX2i tegra flashing hang-ups
Hey all,
I am working on a project that requires use of a specific JetPack 3.2.1 file to flash to multiple TX2i SBCs. I am running into a hang-up while flashing tegra (step shows tegrarcm_v2 --isapplet at hang-up).
I have read all released PCNs for TX2i’s, which indicate specific changes (such as DRAM updates etc) but these only pertain to 699-level part numbers. My lot of SBCs all contain the same 699-part numbers, but I have managed to isolate this issue based on SN:
  • TX2i SBCs beginning with SN 1424- do not have the hang-up issue and flash successfully
  • TX2i SBCs beginning with 1421- hang-up at tegra flash and need to be aborted
Does anyone here happen to have more insight into this issue with JetPack 3.2.1, and is there a potential fix/patch to this specific version that won’t require me to use a newer version?
Rationale for this ask: This project requires use of multiple old legacy software and previous program versions and I am a bit worried the software will have unexpected issues with newer JetPack software versions. I plan to test this in the future, but hoping I can get by with a simple solution.
Thank you!
Note: My issue is similar to this thread however I don’t see a solution that allows retaining the JetPack 3.2- flash.
can you try to use L4T r28.5, which is the latest release for r28 series?
If still does not work, please attach the flashing log so we can further look into it.
