Hi –
I am running Ubuntu 16.04 directly on a PC. No virtual machine. I am using JetPack 3.2.1
I am able to get the image flashed onto the TX2 development board, but the installation of the rest of the tools for the TX2 board hangs here:
Jetpack is unable to determine the IP address of the Jetson Developer Kit
Failure to run bash command “timeout 180 nc -l 33338” because of error: exit status 1,
nc: Address already in use
Please select which action do you want:
- Retry
- Manually Enter IP address
Your option is <1/2>:
If I enter 1, I get the same message.
If I enter 2, the window goes away
If I enter the IP address that I see on eth0 on the TX2 from my minicom connection using ifconfig, I get the same error.
My host and the TX2 are connected to the same router and share the same 192.168.0.xxx address. The netmask for both ports is 255.255.255.0
