The output display of renderer in HDMI is defective when DSI is enabled.
When the display image is still, it looks normal. When the display image moves, there will be flaws. There is a horizontal line, which divides the display image into two parts, one of which is like a delayed image frame.
I have been enabled DSI. This problem is also enabled by DSI, using two display interfaces
xrandr output:
Screen 0: minimum 8 x 8, current 3840 x 1080, maximum 32767 x 32767
DSI-0 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
1920x1080 60.00*+
HDMI-0 connected 1920x1080+1920+0 (normal left inverted right x axis y axis) 520mm x 290mm
1920x1080 60.00*+ 59.95 50.00
1680x1050 59.96
1440x900 59.89
1280x1024 75.03 60.00
1280x960 60.00
1280x720 60.00 59.94 50.00
1024x768 75.03 70.07 60.01
832x624 75.05
800x600 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
720x400 70.04
640x480 75.00 72.81 67.06 59.94 59.94
Any idea please tell me, thanks!
