I spent more than 4 hours trying to flash my Jetson TX1. Jetpack 3.2 can normally be installed on the TX1 and I did before. I flashed my TX1 again but I cannot install it since in the components manager, even though I specify that my platform is the TX1 it reads it as a TX2 and the installation fails. Is that a bug or has it been done on purpose to push TX1 users to get the TX2 ?
I think I may be having the same issue. When the JetPack installer starts I choose TX1. However, at the screen where you select what is installed only the TX2 shows up.
Is that what you’re experiencing?
JetPack lets you select which platform you are working with. If TX1 isn’t showing up on JetPack3.2 (it is a drop-down menu), then you may need to start with a clean directory/install. If you are having network issues perhaps it failed to download a configuration (JetPack does downloads for you).
