On JetPack 3.2 on my Jetson TX2, I am attempting to emulate having 4 GB of memory. I edited /boot/extlinux/extlinux.conf
on the line starting APPEND ${cbootargs} ...
to add mem=4G
, but it has no effect. What am I missing?
Ihab Awad
to add mem=4G
Ihab Awad
Could you flash by 4G parameter.
sudo ./flash.sh -r jetson-tx2-as-4GB mmcblk0p1
I will do my best to try this in the time we have available. Our flashing process is a bit involved. If there’s a way to add a kernel parameter and reboot, that would be awesome.
Ihab
you can either update the memory info
by passing a DRAM mem cfg file with size as 4GB. look for
SDRAM.McEmemCfg = 0x00002000; <== 8gb
this info is then fed to memory node in kernel dts.
so kernel command line will not work anymore
Thank you! – Where would I find this setting? I could not find anything matching in /boot
. Is this in the flashing process?
It’s generate by the sdkmaager like flash.sh the cfg file should be in below directory.
…/JetPack_4.5_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/t186ref/BCT
