NVIDIA is pleased to announce that JetPack 4.0 Developer Preview Early Access is now available for Jetson Xavier. This is an Early Access release of JetPack 4.0 Developer Preview, supporting the new Jetson Xavier Developer Kit. Pre-ordered shipments of the Jetson Xavier Developer Kit are commencing shortly. Please see the Jetson Xavier Developer Kit User Guide for an overview of developer kit features, along with setup and software install instructions.
JetPack 4.0 Developer Preview EA components:
L4T R31.0.1
Ubuntu 18.04 LTS aarch64
CUDA 10.0
cuDNN 7.3
TensorRT 5.0 RC
VisionWorks 1.6
OpenCV 3.3.1
Release Highlights:
Initial Linux BSP support for Jetson Xavier with L4T R31.0.1
Support for Ubuntu 16.04 and Ubuntu 18.04 on the host
Support for Ubuntu 18.04 on the target (Unity desktop is kept as default for this release)
TensorRT 5.0 support for GPU INT8, and CUDA HMMA/IMMA Tensor Core operations
Hi there, do you know where can we get the release notes on TensorRT 5.0? I had submitted a bug report regarding the deconv layers on trt and was waiting on that one.
Cuda 10 is not installing on my Jetson Xavier via Jetpack LT4 4.0. Has anyone else experienced this issue? This is what the log says:
Configuration file '/etc/apt/sources.list.d/cuda-10-0-local-10.0.117.list', does not exist on system.
Installing new config file as you requested.
E: Could not get lock /var/lib/dpkg/lock - open (11: Resource temporarily unavailable)
E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
In my attempt to install the software before the module arrives,
I get this error. System information is below.
Installing OpenCV 3.3.1 failed.
Return Code: 1
Error: libopencv-python libopencv-samples cannot be installed on host. Please manually run following command in terminal to install packages before continuing:
sudo apt install -y /home/tomacorp/nvidia/jetpack_download/16.04/libopencv_3.3.1_amd64.deb /home/tomacorp/nvidia/jetpack_download/16.04/libopencv-dev_3.3.1_amd64.deb /home/tomacorp/nvidia/jetpack_download/16.04/libopencv-python_3.3.1_amd64.deb /home/tomacorp/nvidia/jetpack_download/16.04/libopencv-samples_3.3.1_amd64.deb
I tried running this command manually and it failed with this error:
Preparing to unpack …/libopencv-dev_3.3.1_amd64.deb …
Unpacking libopencv-dev (3.3.1) over (2.4.9.1+dfsg-1.5ubuntu1) …
dpkg: error processing archive /home/tomacorp/nvidia/jetpack_download/16.04/libopencv-dev_3.3.1_amd64.deb (–unpack):
trying to overwrite ‘/usr/include/opencv/cvaux.hpp’, which is also in package libcvaux-dev:amd64 2.4.9.1+dfsg-1.5ubuntu1
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
I restarted the installer and selected to install only OpenCV.
Here is the end of the log file:
/home/tomacorp/nvidia//_installer/run_command -c=“apt install -y /home/tomacorp/nvidia/jetpack_download/16.04/libopencv-samples_3.3.1_amd64.deb” -d=/home/tomacorp/nvidia//_installer/tmp -l=/home/tomacorp/nvidia/_installer/logs//opencv_host_sample.log
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
Reading package lists…
Building dependency tree…
Reading state information…
You might want to run ‘apt-get -f install’ to correct these.
The following packages have unmet dependencies:
libcvaux-dev : Depends: libopencv-core-dev but it is not installed
Depends: libopencv-imgproc-dev but it is not installed
Depends: libopencv-features2d-dev but it is not installed
Depends: libopencv-calib3d-dev but it is not installed
Depends: libopencv-objdetect-dev but it is not installed
Depends: libopencv-legacy-dev but it is not installed
Depends: libopencv-video-dev but it is not installed
Depends: libopencv-contrib-dev but it is not installed
libhighgui-dev : Depends: libopencv-highgui-dev but it is not installed
libopencv-dev : Depends: libopencv-core-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not installed
Depends: libopencv-ml-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not installed
Depends: libopencv-imgproc-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not installed
Depends: libopencv-video-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not installed
Depends: libopencv-objdetect-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not installed
Depends: libopencv-highgui-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not installed
Depends: libopencv-calib3d-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not installed
Depends: libopencv-flann-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not installed
Depends: libopencv-features2d-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not installed
Depends: libopencv-legacy-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not installed
Depends: libopencv-contrib-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not installed
Depends: libopencv-ts-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not installed
Depends: libopencv-photo-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not installed
Depends: libopencv-videostab-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not installed
Depends: libopencv-stitching-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not installed
Depends: libopencv-gpu-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not installed
Depends: libopencv-superres-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not installed
Depends: libopencv-ocl-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not installed
Depends: libcv-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not installed
E: Unmet dependencies. Try using -f.
System information:
Ubuntu 16.04 31.4 GiB memory, Intel® Core™ i7-6700 CPU @ 3.40GHz × 8, Graphics NV106, Disk 950GB, plenty of free space.
Linux dfspxxxx-XPS-8900 4.4.0-135-generic #161-Ubuntu SMP Mon Aug 27 10:45:01 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
Hi tomacorp, does running “sudo apt-get -f install” allow you to proceed? If you aren’t able to build OpenCV from source, you may want to post this in a separate topic for follow-up from the JetPack team. Thanks.
Yes, I am able to proceed after
What fooled me was that when I ran the installer again to get the other packages, the installer uninstalled OpenCV and stopped, and I needed to
again.
Next I set the installer OpenCV Package Action to ‘no action,’ and the installer was able to proceed.
If this is how it is supposed to work, it would be nice to have it in the release notes.
I will file this in https://developer.nvidia.com/content/jetpack-feedback
Oops, I got a 403 forbidden on the jetpack-feedback form (and lost my message!)
Where should I post a topic about the problem and the work-around?
You can post it here to the Jetson Xavier forum, which covers JetPack issues too. That condition shouldn’t be required for everyone, so your feedback is useful for others who may encounter it.
Hi guys, the JetPack server has been restored. We refreshed the CDN, so if you have problems downloading, please clear your browser cache or try incognito mode.
