I’m trying to install Jetpack 4.1.1 DP on Jetson Xavier.
I’m behind a corporate proxy.
I set proxy setting at Host Ubuntu below.
/etc/environment
~.bashrc
But, JetPack 4.1.1 Components Manager gets an error.
Only the message “Error” is displayed on the screen.
Referring to “_installer / Jetpack.log”, the following logs are output.
01-11 19:17:28.4 N: GoogleAnalytics disabled
01-11 19:17:28.4 E: fopen failed with file local.db, errno = 2
Do I need to do something else to avoid errors?
