Now I’m using the Jetson Xavier and I already check the sample : deepstream-app demonstration with RTSP input.
Now I’m using the Nsight Eclipse Edition with using Cuda-toolkit-10.0
My question is how to import the deepstream sdk(library file) to Nsight Eclipse ?
what i’d like to do is get each frame from RTSP video input on my own application.
I couldn’t get example source cord and tutorial about above things.
Is there any guide for Deepstream SDK to Nsight Eclipse?
I’ve found the dsexample guide for custom plugin template and I made the “libgstnvdsexample.so” file which is library to import to my own application I guess.
but i have no idea with the “libgstnvdsexample.so” to import to Nsight Eclipse.
anyone can help ?
We now only support to build the app on target. other forum users may share experience of using Nsight Eclipse + DeepStream SDK.
For RTSP, please refer to
[url]https://devtalk.nvidia.com/default/topic/1046315/deepstream-sdk-on-jetson/template-config-file-for-camera-and-rtsp/post/5314984/#5314984[/url]
Hi DaneLLL
Thank you for reply,
my own application means not sample as deepstream-app
I’d like to import deepstream libray on my application(host) and remotely build up on target(xavier)
because it needs too long time to understand the sample source cord
I just want to know the way that import the deepstream library(as i mentioned “libgstnvdsexample.so”) and develope app on Nsight Eclipse step by step, refer to guide of deepstream function’s
