Jetpack 4.11 setup failes
Im trying to setup jetpack4.11 on Jetson xavier, but it fails so far.
When I give command “./JetPack-L4T-4.1.1-linux-x64_b57.run”
The command manager shows blank list.
Log shows “03-12 15:29:09.5 E: fopen failed with file local.db, errno = 2”.
I think there is some programs with network setting, but i am not sure since I can connect to internet with blowser or wget comand.
Could someone give me ideas to solve problems?
Hi sumie.okubo,
Please following the JetPack install guide to try again. Thanks!
[url]https://docs.nvidia.com/jetson/jetpack/index.html#jetpack/4.1.1/install.htm%3FTocPath%3D_____3[/url]
Please make sure your Linux host computer is Ubuntu Linux x64 Version 18.04 or 16.04.
I have already followed install instruction and it failed when executing run file before boosting Xavier.
I also checked Linux computer host is Ubuntu Linux x64 and version is 16.04.
Hi sumie.okubo,
I think it should be your network issue.
Please check your Ethernet and proxy setting.
If still can’t install JetPack, please attached logs.
some reference found that looks having similar sympthoms: https://devtalk.nvidia.com/default/topic/1033040/jetson-tx2/install-jetpack-3-2-failed-quot-e-fopen-failed-with-file-local-db-errno-2-quot-/
