JetPack 4.2.1 Intallation Failing on Xavier
Please find log files generated from failed installation below https://www.dropbox.com/s/y4gyyvjrmdsyatp/SDKM_logs_JetPack_4.2.1_(rev.1)_Linux_for_Jetson_AGX_Xavier_2019-08-18_19-00-31.zip?dl=0
Thank you,
Installation succeeded after excluding host, selecting Jetson OS only from target components letting that go through and finally selecting Jetson SDK components only which went through as well.
Hi omisaleh,
We have found a 403 issue with the package tokens coming from the server and are working to identify the root cause. Will let you know when a fix has been implemented. Thanks for your patience as we resolve this.
Hi omisaleh,
Issue should be fixed already, please try download the SDK manager to do the installation again.
