Hi.
We will bring up the Jetpack 4.2 camera from TX2 board.
We are bring up a camera that has its own ISP.
So we made the necessary settings for the device tree.
So we first confirmed that it works in Jetpack 3.1.
The camera worked well with JETPACK 3.1.
Jetpack 4.2 also sets only the essential values for the device tree.
However, Jetpack 4.2 does not work.
Strange thing
Lowering the camera clock will work.
We thought that we did not need any special settings related to Clock to use ISP, but …
I am embarrassed to have a problem with Jetpack 4.2.
The settings in Jetpack 3.1 are almost identical to those in Jetpack 4.2.
As shown below.
We desperately want the issue resolved.
Thank you for your help.
Thank you.
JETPACK 3.1
host1x {
vi@15700000 {
num-channels = <3>;
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
hmns0000_aggregate_vi_in0: endpoint {
csi-port = <0>;
bus-width = <4>;
remote-endpoint = <&hmns0000_aggregate_csi_out0>;
port@1 {
reg = <1>;
hmns0000_aggregate_vi_in1: endpoint {
csi-port = <2>;
bus-width = <4>;
remote-endpoint = <&hmns0000_aggregate_csi_out1>;
port@2 {
reg = <2>;
hmns0000_aggregate_vi_in2: endpoint {
csi-port = <4>;
bus-width = <4>;
remote-endpoint = <&hmns0000_aggregate_csi_out2>;
nvcsi@150c0000 {
num-channels = <3>;
#size-cells = <0>;
channel@0 {
reg = <0>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
hmns0000_aggregate_csi_in0: endpoint@0 {
csi-port = <0>;
bus-width = <4>;
remote-endpoint = <&hmns0000_aggregate_hmns0000_out0>;
port@1 {
reg = <1>;
hmns0000_aggregate_csi_out0: endpoint@1 {
remote-endpoint = <&hmns0000_aggregate_vi_in0>;
channel@1 {
reg = <1>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
hmns0000_aggregate_csi_in1: endpoint@2 {
csi-port = <2>;
bus-width = <4>;
remote-endpoint = <&hmns0000_aggregate_hmns0000_out1>;
port@1 {
reg = <1>;
hmns0000_aggregate_csi_out1: endpoint@3 {
remote-endpoint = <&hmns0000_aggregate_vi_in1>;
channel@2 {
reg = <2>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
hmns0000_aggregate_csi_in2: endpoint@4 {
csi-port = <4>;
bus-width = <4>;
remote-endpoint = <&hmns0000_aggregate_hmns0000_out2>;
port@1 {
reg = <1>;
hmns0000_aggregate_csi_out2: endpoint@5 {
remote-endpoint = <&hmns0000_aggregate_vi_in2>;
i2c@3180000 {
hmns0000@10 {
compatible = "nvidia,hmns0000";
/* I2C device address */
reg = <0x10>;
mode0 { //1280x720
mclk_khz = "24000";
num_lanes = "4";
discontinuous_clk = "no";
dpcm_enable = "false";
cil_settletime = "0";
active_w = "1280";
active_h = "720";
pixel_t = "uyvy";
line_length = "1280";
pix_clk_hz = "74000000";
min_framerate = "1";
max_framerate = "30";
embedded_metadata_height = "0";
mode1 { //1280x800
mclk_khz = "24000";
num_lanes = "4";
active_w = "1280";
active_h = "800";
pixel_t = "uyvy";
mode2 { //2560x800
mclk_khz = "24000";
num_lanes = "4";
active_w = "2560";
active_h = "800";
pixel_t = "uyvy";
line_length = "2560";
mode3 { //3840x800
mclk_khz = "24000";
num_lanes = "4";
active_w = "3840";
active_h = "800";
pixel_t = "uyvy";
line_length = "3840";
mode4 { //5120x800
mclk_khz = "24000";
num_lanes = "4";
active_w = "5120";
active_h = "800";
pixel_t = "uyvy";
line_length = "5120";
mode5 { //HMNS0000_MODE_1920X1208
mclk_khz = "24000";
num_lanes = "4";
active_w = "1920";
active_h = "1208";
pixel_t = "bayer_rggb";
readout_orientation = "0";
line_length = "1354";
inherent_gain = "1";
mclk_multiplier = "25";
pix_clk_hz = "84000000";
gain_factor = "16";
framerate_factor = "1";
min_gain_val = "1";
max_gain_val = "256";
min_exp_time = "34";
max_exp_time = "999994";
embedded_metadata_height = "24";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
hmns0000_aggregate_hmns0000_out0: endpoint {
csi-port = <0>;
bus-width = <4>;
remote-endpoint = <&hmns0000_aggregate_csi_in0>;
hmns0000@20 {
reg = <0x20>;
mode0 { //1280x720
mclk_khz = "24000";
num_lanes = "4";
tegra_sinterface = "serial_c";
active_w = "1280";
active_h = "720";
pixel_t = "uyvy";
mode1 { //1280x800
mclk_khz = "24000";
num_lanes = "4";
active_w = "1280";
active_h = "800";
pixel_t = "uyvy";
mode2 { //2560x800
mclk_khz = "24000";
num_lanes = "4";
active_w = "2560";
active_h = "800";
pixel_t = "uyvy";
mode3 { //3840x800
mclk_khz = "24000";
num_lanes = "4";
active_w = "3840";
active_h = "800";
pixel_t = "uyvy";
mode4 { //5120x800
mclk_khz = "24000";
num_lanes = "4";
active_w = "5120";
active_h = "800";
pixel_t = "uyvy";
mclk_khz = "24000";
num_lanes = "4";
active_w = "1920";
active_h = "1208";
gain_factor = "16";
min_gain_val = "1";
mode6 { //1920x1080
mclk_khz = "24000";
num_lanes = "4";
active_w = "1920";
active_h = "1080";
pixel_t = "uyvy";
line_length = "1920";
mode7 { //3840x1080
mclk_khz = "24000";
num_lanes = "4";
active_w = "3840";
active_h = "1080";
pixel_t = "uyvy";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
hmns0000_aggregate_hmns0000_out1: endpoint {
csi-port = <2>;
bus-width = <4>;
remote-endpoint = <&hmns0000_aggregate_csi_in1>;
hmns0000@40 {
reg = <0x40>;
mode0 { //1280x720
mclk_khz = "24000";
num_lanes = "4";
tegra_sinterface = "serial_e";
active_w = "1280";
active_h = "720";
pixel_t = "uyvy";
mode1 { //1280x800
mclk_khz = "24000";
num_lanes = "4";
active_w = "1280";
active_h = "800";
pixel_t = "uyvy";
mode2 { //2560x800
mclk_khz = "24000";
num_lanes = "4";
active_w = "2560";
active_h = "800";
pixel_t = "uyvy";
mode3 { //3840x800
mclk_khz = "24000";
num_lanes = "4";
active_w = "3840";
active_h = "800";
pixel_t = "uyvy";
mode4 { //5120x800
mclk_khz = "24000";
num_lanes = "4";
active_w = "5120";
active_h = "800";
pixel_t = "uyvy";
mclk_khz = "24000";
num_lanes = "4";
active_w = "1920";
active_h = "1208";
gain_factor = "16";
min_gain_val = "1";
mode6 { //1920x1080
mclk_khz = "24000";
num_lanes = "4";
active_w = "1920";
active_h = "1080";
pixel_t = "uyvy";
mode7 { //3840x1080
mclk_khz = "24000";
num_lanes = "4";
active_w = "3840";
active_h = "1080";
pixel_t = "uyvy";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
hmns0000_aggregate_hmns0000_out2: endpoint {
csi-port = <4>;
bus-width = <4>;
remote-endpoint = <&hmns0000_aggregate_csi_in2>;
tegra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
* Physical settings to calculate max ISO BW
* num_csi_lanes = <>;
* Total number of CSI lanes when all cameras are active
* max_lane_speed = <>;
* Max lane speed in Kbit/s
* min_bits_per_pixel = <>;
* Min bits per pixel
* vi_peak_byte_per_pixel = <>;
* Max byte per pixel for the VI ISO case
* vi_bw_margin_pct = <>;
* Vi bandwidth margin in percentage
* max_pixel_rate = <>;
* Max pixel rate in Kpixel/s for the ISP ISO case
* isp_peak_byte_per_pixel = <>;
* Max byte per pixel for the ISP ISO case
* isp_bw_margin_pct = <>;
* Isp bandwidth margin in percentage
num_csi_lanes = <12>;
max_lane_speed = <1500000>;
min_bits_per_pixel = <10>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
max_pixel_rate = <750000>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;
JETPACK 3.1
host1x {
vi@15700000 {
num-channels = <3>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
port-index = <0>;
bus-width = <4>;
port@1 {
reg = <1>;
port-index = <2>;
bus-width = <2>;
port@2 {
reg = <2>;
csi-port = <4>;
bus-width = <4>;
nvcsi@150c0000 {
num-channels = <3>;
#size-cells = <0>;
channel@0 {
reg = <0>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
port-index = <0>;
bus-width = <4>;
port@1 {
reg = <1>;
channel@1 {
reg = <1>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
port-index = <2>;
bus-width = <2>;
port@1 {
reg = <1>;
channel@2 {
reg = <2>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
csi-port = <4>;
bus-width = <4>;
port@1 {
reg = <1>;
i2c@3180000 {
hmns0000@10 {
reg = <0x10>;
mode0 { //1280x720
mclk_khz = "24000";
num_lanes = "4";
phy_mode = "DPHY";
active_w = "1280";
active_h = "720";
pixel_t = "uyvy";
mode1 { //1280x800
mclk_khz = "24000";
num_lanes = "4";
phy_mode = "DPHY";
active_w = "1280";
active_h = "800";
pixel_t = "uyvy";
mode2 { //2560x800
mclk_khz = "24000";
num_lanes = "4";
phy_mode = "DPHY";
active_w = "2560";
active_h = "800";
pixel_t = "uyvy";
mode3 { //3840x800
mclk_khz = "24000";
num_lanes = "4";
phy_mode = "DPHY";
active_w = "3840";
active_h = "800";
pixel_t = "uyvy";
mode4 { //5120x800
mclk_khz = "24000";
num_lanes = "4";
phy_mode = "DPHY";
active_w = "5120";
active_h = "800";
pixel_t = "uyvy";
mclk_khz = "24000";
num_lanes = "4";
phy_mode = "DPHY";
active_w = "1920";
active_h = "1208";
gain_factor = "16";
min_gain_val = "1";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
port-index = <0>;
bus-width = <4>;
hmns0000@20 {
reg = <0x20>;
mode0 { //1280x720
mclk_khz = "24000";
num_lanes = "4";
phy_mode = "DPHY";
active_w = "1280";
active_h = "720";
pixel_t = "uyvy";
mode1 { //1280x800
mclk_khz = "24000";
num_lanes = "4";
phy_mode = "DPHY";
active_w = "1280";
active_h = "800";
pixel_t = "uyvy";
mode2 { //2560x800
mclk_khz = "24000";
num_lanes = "4";
phy_mode = "DPHY";
active_w = "2560";
active_h = "800";
pixel_t = "uyvy";
mode3 { //3840x800
mclk_khz = "24000";
num_lanes = "4";
phy_mode = "DPHY";
active_w = "3840";
active_h = "800";
pixel_t = "uyvy";
mode4 { //5120x800
mclk_khz = "24000";
num_lanes = "4";
phy_mode = "DPHY";
active_w = "5120";
active_h = "800";
pixel_t = "uyvy";
mclk_khz = "24000";
num_lanes = "4";
phy_mode = "DPHY";
active_w = "1920";
active_h = "1208";
gain_factor = "16";
min_gain_val = "1";
mode6 { //1920x1080
mclk_khz = "24000";
num_lanes = "4";
phy_mode = "DPHY";
active_w = "1920";
active_h = "1080";
pixel_t = "uyvy";
mode7 { //3840x1080
mclk_khz = "24000";
num_lanes = "4";
phy_mode = "DPHY";
active_w = "3840";
active_h = "1080";
pixel_t = "uyvy";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
port-index = <2>;
bus-width = <2>;
hmns0000@40 {
reg = <0x40>;
mode0 { //1280x720
mclk_khz = "24000";
num_lanes = "4";
phy_mode = "DPHY";
active_w = "1280";
active_h = "720";
pixel_t = "uyvy";
mode1 { //1280x800
mclk_khz = "24000";
num_lanes = "4";
phy_mode = "DPHY";
active_w = "1280";
active_h = "800";
pixel_t = "uyvy";
mode2 { //2560x800
mclk_khz = "24000";
num_lanes = "4";
phy_mode = "DPHY";
active_w = "2560";
active_h = "800";
pixel_t = "uyvy";
mode3 { //3840x800
mclk_khz = "24000";
num_lanes = "4";
phy_mode = "DPHY";
active_w = "3840";
active_h = "800";
pixel_t = "uyvy";
mode4 { //5120x800
mclk_khz = "24000";
num_lanes = "4";
phy_mode = "DPHY";
active_w = "5120";
active_h = "800";
pixel_t = "uyvy";
mclk_khz = "24000";
num_lanes = "4";
phy_mode = "DPHY";
active_w = "1920";
active_h = "1208";
gain_factor = "16";
min_gain_val = "1";
mode6 { //1920x1080
mclk_khz = "24000";
num_lanes = "4";
phy_mode = "DPHY";
active_w = "1920";
active_h = "1080";
pixel_t = "uyvy";
mode7 { //3840x1080
mclk_khz = "24000";
num_lanes = "4";
phy_mode = "DPHY";
active_w = "3840";
active_h = "1080";
pixel_t = "uyvy";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
port-index = <4>;
bus-width = <4>;
