Hello everyone.
We tried latest JetPack 4.2 with sdk manger on Xavier and TX2.
After flashing you need to configure system, but mouse and keyboard doesn’t work. I tried all ports, but it doesn’t help.
On tx2 there was no such error.
Thanks and Best Regards,
Andrey
Do you stuck at the moment when system gives out the prompt to ask username/pwd?
I tried before and at the moment, but result is the same
Hi tiger_assassin_crazy,
Could you please try plug-in kayboard or mouse to USB port dirctly?
Or change others usb hub and try again.
Hello carolyuu. Thanks for your reply!
I did it, but it doen’t help. Do you have a “factory” image then can i restore or something?
Do you have serial console or ssh access? If so, what does “lsusb” show (and “lsusb -t”)? What does “dmesg --follow” show as the keyboard is plugged in or unplugged?
Took several tries to get it to work on my Xavier. Had to do it from machine with real ethernet connection. From laptop with only wifi never could get it to work. The way I did it was to move monitor and keyboard from intel machine to xavier to finish set-up before it would complete.
danpollock,
Are you able to move your mouse after that?
Hello everyone.
The problem was that i use my Xavier with an Intel Dual Band 8660. When i removed it, usb ports started working
Thanks for your replies and Best Regards
hello everyone.
I have same issue but on TX2 not Xavier, un-plug everything just using usb mouse.
It dosen’t work…
wsywsya119,
Please file a topic on tx2 forum board. We will help check.
There are the error code while flash jetpack. It still finished but when boot TX2 can’t move the usb mouse.
16:39:22 ERROR : command terminated with error
16:40:25 ERROR : Flash Jetson TX2 : lost connection
16:41:51 ERROR : Flash Jetson TX2 : Board ID(3310) version(B02) sku(1000) revision(E.0)
16:42:26 ERROR : Flash Jetson TX2 :
16:42:26 ERROR : Flash Jetson TX2 : 0: RAW: 4263936( 1041 blks) ==> 28:4263948
16:42:26 ERROR : Flash Jetson TX2 : 1: SKP: 16384( 4 blks) ==> 4263976:12
16:42:26 ERROR : Flash Jetson TX2 : 2: RAW: 12288( 3 blks) ==> 4263988:12300
16:42:27 ERROR : Flash Jetson TX2 : 3: SKP: 53248( 13 blks) ==> 4276288:12
16:42:27 ERROR : Flash Jetson TX2 : 4: RAW: 5812224( 1419 blks) ==> 4276300:5812236
16:42:27 ERROR : Flash Jetson TX2 : 5: SKP: 27742208( 6773 blks) ==> 10088536:12
16:42:27 ERROR : Flash Jetson TX2 : 6: RAW: 13709312( 3347 blks) ==> 10088548:13709324
16:42:27 ERROR : Flash Jetson TX2 : 7: SKP: 82608128( 20168 blks) ==> 23797872:12
16:42:27 ERROR : Flash Jetson TX2 : 8: RAW: 20480( 5 blks) ==> 23797884:20492
16:42:27 ERROR : Flash Jetson TX2 : 9: SKP: 4313088( 1053 blks) ==> 23818376:12
16:42:27 ERROR : Flash Jetson TX2 : 10: RAW: 3452928( 843 blks) ==> 23818388:3452940
16:42:27 ERROR : Flash Jetson TX2 : 12: RAW: 16097280( 3930 blks) ==> 27271340:16097292
16:42:27 ERROR : Flash Jetson TX2 : 14: RAW: 147456( 36 blks) ==> 43368644:147468
16:42:27 ERROR : Flash Jetson TX2 : 16: RAW: 77824( 19 blks) ==> 43516124:77836
16:42:27 ERROR : Flash Jetson TX2 : 17: SKP: 4096( 1 blks) ==> 43593960:12
16:42:27 ERROR : Flash Jetson TX2 : 18: RAW: 331776( 81 blks) ==> 43593972:331788
16:42:27 ERROR : Flash Jetson TX2 : 20: RAW: 794624( 194 blks) ==> 43925772:794636
16:42:27 ERROR : Flash Jetson TX2 : 22: RAW: 57344( 14 blks) ==> 44720420:57356
16:42:27 ERROR : Flash Jetson TX2 : 23: SKP: 8192( 2 blks) ==> 44777776:12
16:42:27 ERROR : Flash Jetson TX2 : 24: RAW: 131072( 32 blks) ==> 44777788:131084
16:42:27 ERROR : Flash Jetson TX2 : 25: SKP: 294912( 72 blks) ==> 44908872:12
16:42:27 ERROR : Flash Jetson TX2 : 26: RAW: 4182016( 1021 blks) ==> 44908884:4182028
16:42:27 ERROR : Flash Jetson TX2 : 28: RAW: 196608( 48 blks) ==> 49090924:196620
16:42:27 ERROR : Flash Jetson TX2 : 29: SKP: 274432( 67 blks) ==> 49287544:12
16:42:27 ERROR : Flash Jetson TX2 : 30: RAW: 278528( 68 blks) ==> 49287556:278540
16:42:27 ERROR : Flash Jetson TX2 : 31: SKP: 20480( 5 blks) ==> 49566096:12
16:42:27 ERROR : Flash Jetson TX2 : 32: RAW: 430080( 105 blks) ==> 49566108:430092
16:42:27 ERROR : Flash Jetson TX2 : 34: RAW: 8192( 2 blks) ==> 49996212:8204
16:42:27 ERROR : Flash Jetson TX2 : 35: SKP: 1339392( 327 blks) ==> 50004416:12
Please file topic on TX2 board… this board is for Xavier.
