I am facing an Flash error “Jetson TX2: No such file or directory**” while flashing jetpack manually through forced recovery mode in TX2. I am using ubuntu 18.04. I have attached logs at bottom.
16:23:10 DEBUG: Flash Jetson TX2: using adapter to install NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2 to /home/user/Desktop/jetpack/nvidia_sdk1/JetPack_4.2_Linux_JETSON_TX2
- 16:23:10 INFO: Flash Jetson TX2: [ Disk Avail:45 GB ]
- 16:23:10 INFO: Flash Jetson TX2: Using GenericInstaller to Install NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP
- 16:23:10 INFO: Flash Jetson TX2: change working directory to /home/user/Desktop/jetpack/nvidia_sdk1/JetPack_4.2_Linux_JETSON_TX2/Linux_for_Tegra
- 16:23:10 INFO: Flash Jetson TX2: [ Component Install Started ]
- 16:23:10 INFO: Flash Jetson TX2: current working directory is /home/user/Desktop/jetpack/nvidia_sdk1/JetPack_4.2_Linux_JETSON_TX2/Linux_for_Tegra
- 16:23:10 INFO: Flash Jetson TX2: exec_command [target]:
- 16:23:10 INFO: Flash Jetson TX2: **********************
- 16:23:10 INFO: Flash Jetson TX2: #!/bin/bash
- 16:23:10 INFO: Flash Jetson TX2: set -e
- 16:23:10 INFO: Flash Jetson TX2: export LC_ALL=en_US.UTF-8 LANG=en_US.UTF-8 LANGUAGE=en_US.UTF-8
- 16:23:10 INFO: Flash Jetson TX2: sudo reboot forced-recovery
- 16:23:10 INFO: Flash Jetson TX2: exec_command: scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP.sh @:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no @ “~/tmp_NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP.sh && rm -f ~/tmp_NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP.sh”
- 16:23:15 INFO: Flash Jetson TX2: [-D [bind_address:]port] [-E log_file] [-e escape_char]
- 16:23:15 INFO: Flash Jetson TX2: [-F configfile] [-I pkcs11] [-i identity_file]
- 16:23:15 INFO: Flash Jetson TX2: [-J [user@]host[:port]] [-L address] [-l login_name] [-m mac_spec]
- 16:23:15 INFO: Flash Jetson TX2: [-O ctl_cmd] [-o option] [-p port] [-Q query_option] [-R address]
- 16:23:15 INFO: Flash Jetson TX2: [-S ctl_path] [-W host:port] [-w local_tun[:remote_tun]]
- 16:23:15 INFO: Flash Jetson TX2: [user@]hostname [command]
- 16:23:15 : Flash Jetson TX2: [exec_command]: /bin/bash -c scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP.sh @:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no @ “~/tmp_NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP.sh && rm -f ~/tmp_NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP.sh”; [error]: usage: ssh [-46AaCfGgKkMNnqsTtVvXxYy] [-b bind_address] [-c cipher_spec]
- 16:23:15 INFO: Flash Jetson TX2: , but ignored
- 16:23:15 INFO: Flash Jetson TX2: exec_command: sleep 20
- 16:23:35 INFO: Flash Jetson TX2: exec_command: sudo ./flash.sh jetson-tx2 mmcblk0p1
- 16:23:35 INFO: Flash Jetson TX2: [host] [sudo] password for ankit:
- 16:23:36 INFO: Flash Jetson TX2: ###############################################################################
- 16:23:36 INFO: Flash Jetson TX2: # L4T BSP Information:
- 16:23:36 INFO: Flash Jetson TX2: # R32 (release), REVISION: 1.0, GCID: 14531094, BOARD: t186ref, EABI: aarch64,
- 16:23:36 INFO: Flash Jetson TX2: # DATE: Wed Mar 13 07:41:08 UTC 2019
- 16:23:37 INFO: Flash Jetson TX2: # Target Board Information:
- 16:23:37 INFO: Flash Jetson TX2: # Name: jetson-tx2, Board Family: t186ref, SoC: Tegra 186,
- 16:23:37 INFO: Flash Jetson TX2: # OpMode: production, Boot Authentication: NS,
- 16:23:37 INFO: Flash Jetson TX2: ###############################################################################
- 16:23:37 INFO: Flash Jetson TX2: ./tegraflash.py --chip 0x18 --applet “/home/user/Desktop/jetpack/nvidia_sdk1/JetPack_4.2_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin” --skipuid --cmd “dump eeprom boardinfo cvm.bin”
- 16:23:38 INFO: Flash Jetson TX2: Reading board information failed.
- 16:23:38 INFO: Flash Jetson TX2: [ Component Install Finished with Error ]
- 16:23:38 INFO: Flash Jetson TX2: [ 4.21 MB used. Disk Avail: 41.12 GB ]
- 16:23:38 INFO: Flash Jetson TX2: [ NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP Install took 28s ]
- 16:23:38 SUMMARY: Flash Jetson TX2: No such file or directory
