I know that this topic has been discussed a lot but I still want to make clear my progress up until now.
Host computer: DELL XPS15 with Pop!OS 18.04, Anaconda installed (for my research).
Edge: Nvidia AGX Xavier (Code: P2972).
First, I encountered with bzip2 error. It seems to work with alternative bzip2 following this thread.
https://devtalk.nvidia.com/default/topic/1056381/jetson-agx-xavier/jetpack-4-2-xavier-install-failed/2
Second, I encountered with Connection lost due to python. Skim through the forum I founded some solutions
https://devtalk.nvidia.com/default/topic/1051032/jetson-agx-xavier/jetson-agx-xavier-flash-failure/
https://devtalk.nvidia.com/default/topic/1049253/jetson-tx2/error-flash-jetson-tx2-lost-connection/
I checked and my system said that I have installed python 2.7.15~rc1-1 but when I tried to run command python from the terminal, I still get the python 3 work. This might due to Anaconda.
- So that my first try is to create an environment in Anaconda with python 2.7, it did not work
- My second try is to deactive Anaconda inside .bashrc and confirmed that python command give me python 2.7
$ python
Python 2.7.15+ (default, Nov 27 2018, 23:36:35)
[GCC 7.3.0] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> exit()
Then I tried again but still failed with SDK Manager or manual flash.
~/nvidia/nvidia_sdk/JetPack_4.2_Linux_P2888/Linux_for_Tegra$ sudo ./flash.sh jetson-xavier mmcblk0p1
# L4T BSP Information:
# R32 (release), REVISION: 1.0, GCID: 14531094, BOARD: t186ref, EABI: aarch64,
# DATE: Wed Mar 13 07:41:08 UTC 2019
Error: probing the target board failed.
Make sure the target board is connected through
USB port and is in recovery mode.
Anyone know how to solve this problem?
