I installed JetPack 4.2 on Ubuntu 18.04, ran “sdkmanager”, entered credentials. At step 1 deselected Host Machine and selected Target Host = Jetson TX2. Clicked Continue and I see “OOPS, Could not load the NVIDIA SDK details”.
In the exported logs I see an error about loading “sdkml3_jetpack_l4t_42.json”. The file contains:
$ cat ~/.nvsdkm/dist/sdkml3_jetpack_l4t_42.json
html/body/script <<< Edited so I can post the message on the forum
var url = window.location.pathname;
var filename = url.substring(url.lastIndexOf('/')+1);
window.location = "http://developer.nvidia.com/restricted?filename="+filename
info: sdkml3_jetpack_l4t_42.json from https://developer.download.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2/JETPACK_42_b158/sdkml3_jetpack_l4t_42.json?......edited...... has been downloaded to /home/edited/.nvsdkm/dist successfully.
error:
{ message: '/home/edited/.nvsdkm/dist/sdkml3_jetpack_l4t_42.json: Unexpected token < in JSON at position 0',
