JetPack 4.3 and CTI-L4T Board Support Package Version: V003
Hello, I’m trying to install the latest L4Tr32.3.1 - Jetpack 4.3 board support package.
I’m using the instructions from: http://connecttech.com/resource-center/kdb373/
When I get to the step “sudo ./install.sh”, I get the following error dialog.
Usage: ./install.sh
Before installing this BSP, please read the included readme.txt
To switch between different products, the TX2/TX2i/TX2-4G will need to be re-flashed
Ensure to extract clean rootfs
Below are the compatible L4T versions and board profiles:
Supported Version Information
Supported Linux for Tegra Release Versions:
32.3.1
Supported Nvidia Jetson Module Hardware:
TX2
TX2i
TX2-4G
~/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_TX2/Linux_for_Tegra ~/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_TX2/Linux_for_Tegra/CTI-L4T
Using rootfs directory of: /home/pfurey/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_TX2/Linux_for_Tegra/rootfs
/home/pfurey/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_TX2/Linux_for_Tegra/nv_tegra/nv-apply-debs.sh
Root file system directory is /home/pfurey/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_TX2/Linux_for_Tegra/rootfs
Copying public debian packages to rootfs
Start L4T BSP package installation
QEMU binary is not available, looking for QEMU from host system
Found /usr/bin/qemu-aarch64-static
Installing QEMU binary in rootfs
Installing Jetson OTA server key in rootfs
~/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_TX2/Linux_for_Tegra/rootfs ~/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_TX2/Linux_for_Tegra
Registering Jetson OTA server key
OK
Removing Jetson OTA server key from rootfs
Installing BSP Debian packages in /home/pfurey/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_TX2/Linux_for_Tegra/rootfs
(Reading database … 120915 files and directories currently installed.)
Preparing to unpack …/nvidia-l4t-ccp-t186ref_32.3.1-20191209230245_arm64.deb …
Pre-installing… skip compatibility checking.
Unpacking nvidia-l4t-ccp-t186ref (32.3.1-20191209230245) over (32.3.1-20191209230245) …
Setting up nvidia-l4t-ccp-t186ref (32.3.1-20191209230245) …
Preparing to unpack …/jetson-gpio-common_2.0.4_arm64.deb …
Unpacking jetson-gpio-common (2.0.4) over (2.0.4) …
Preparing to unpack …/python3-jetson-gpio_2.0.4_arm64.deb …
qemu: Unsupported syscall: 278
Fatal Python error: failed to get random numbers to initialize Python
qemu: uncaught target signal 6 (Aborted) - core dumped
Aborted (core dumped)
dpkg: warning: old python3-jetson-gpio package pre-removal script subprocess returned error exit status 134
dpkg: trying script from the new package instead …
dpkg: error processing archive /opt/nvidia/l4t-packages/standalone/python3-jetson-gpio_2.0.4_arm64.deb (–install):
new python3-jetson-gpio package pre-removal script subprocess returned error exit status 134
Preparing to unpack …/python-jetson-gpio_2.0.4_arm64.deb …
Unpacking python-jetson-gpio (2.0.4) over (2.0.4) …
Preparing to unpack …/nvidia-l4t-3d-core_32.3.1-20191209230245_arm64.deb …
Unpacking nvidia-l4t-3d-core (32.3.1-20191209230245) over (32.3.1-20191209230245) …
Preparing to unpack …/nvidia-l4t-apt-source_32.3.1-20191209230245_arm64.deb …
Unpacking nvidia-l4t-apt-source (32.3.1-20191209230245) over (32.3.1-20191209230245) …
Preparing to unpack …/nvidia-l4t-camera_32.3.1-20191209230245_arm64.deb …
Unpacking nvidia-l4t-camera (32.3.1-20191209230245) over (32.3.1-20191209230245) …
Preparing to unpack …/nvidia-l4t-configs_32.3.1-20191209230245_arm64.deb …
Unpacking nvidia-l4t-configs (32.3.1-20191209230245) over (32.3.1-20191209230245) …
Preparing to unpack …/nvidia-l4t-core_32.3.1-20191209230245_arm64.deb …
Unpacking nvidia-l4t-core (32.3.1-20191209230245) over (32.3.1-20191209230245) …
Preparing to unpack …/nvidia-l4t-cuda_32.3.1-20191209230245_arm64.deb …
Unpacking nvidia-l4t-cuda (32.3.1-20191209230245) over (32.3.1-20191209230245) …
Preparing to unpack …/nvidia-l4t-firmware_32.3.1-20191209230245_arm64.deb …
Unpacking nvidia-l4t-firmware (32.3.1-20191209230245) over (32.3.1-20191209230245) …
Preparing to unpack …/nvidia-l4t-graphics-demos_32.3.1-20191209230245_arm64.deb …
Unpacking nvidia-l4t-graphics-demos (32.3.1-20191209230245) over (32.3.1-20191209230245) …
Preparing to unpack …/nvidia-l4t-gstreamer_32.3.1-20191209230245_arm64.deb …
Unpacking nvidia-l4t-gstreamer (32.3.1-20191209230245) over (32.3.1-20191209230245) …
Preparing to unpack …/nvidia-l4t-init_32.3.1-20191209230245_arm64.deb …
Unpacking nvidia-l4t-init (32.3.1-20191209230245) over (32.3.1-20191209230245) …
Preparing to unpack …/nvidia-l4t-initrd_32.3.1-20191209230245_arm64.deb …
Unpacking nvidia-l4t-initrd (32.3.1-20191209230245) over (32.3.1-20191209230245) …
Preparing to unpack …/nvidia-l4t-jetson-io_4.9.140-tegra-32.3.1-20200526-CTI-TX2-V003_arm64.deb …
Unpacking nvidia-l4t-jetson-io (4.9.140-tegra-32.3.1-20200526-CTI-TX2-V003) over (4.9.140-tegra-32.3.1-20200526-CTI-TX2-V003) …
Preparing to unpack …/nvidia-l4t-multimedia_32.3.1-20191209230245_arm64.deb …
Unpacking nvidia-l4t-multimedia (32.3.1-20191209230245) over (32.3.1-20191209230245) …
Preparing to unpack …/nvidia-l4t-multimedia-utils_32.3.1-20191209230245_arm64.deb …
Unpacking nvidia-l4t-multimedia-utils (32.3.1-20191209230245) over (32.3.1-20191209230245) …
Preparing to unpack …/nvidia-l4t-oem-config_32.3.1-20191209230245_arm64.deb …
Unpacking nvidia-l4t-oem-config (32.3.1-20191209230245) over (32.3.1-20191209230245) …
Preparing to unpack …/nvidia-l4t-tools_32.3.1-20191209230245_arm64.deb …
Unpacking nvidia-l4t-tools (32.3.1-20191209230245) over (32.3.1-20191209230245) …
Preparing to unpack …/nvidia-l4t-wayland_32.3.1-20191209230245_arm64.deb …
Unpacking nvidia-l4t-wayland (32.3.1-20191209230245) over (32.3.1-20191209230245) …
Preparing to unpack …/nvidia-l4t-weston_32.3.1-20191209230245_arm64.deb …
Unpacking nvidia-l4t-weston (32.3.1-20191209230245) over (32.3.1-20191209230245) …
Preparing to unpack …/nvidia-l4t-x11_32.3.1-20191209230245_arm64.deb …
Unpacking nvidia-l4t-x11 (32.3.1-20191209230245) over (32.3.1-20191209230245) …
Preparing to unpack …/nvidia-l4t-xusb-firmware_32.3.1-20191209230245_arm64.deb …
Unpacking nvidia-l4t-xusb-firmware (32.3.1-20191209230245) over (32.3.1-20191209230245) …
Preparing to unpack …/nvidia-l4t-kernel_4.9.140-tegra-32.3.1-20200526-CTI-TX2-V003_arm64.deb …
Unpacking nvidia-l4t-kernel (4.9.140-tegra-32.3.1-20200526-CTI-TX2-V003) over (4.9.140-tegra-32.3.1-20200526-CTI-TX2-V003) …
Preparing to unpack …/nvidia-l4t-kernel-dtbs_4.9.140-tegra-32.3.1-20200526-CTI-TX2-V003_arm64.deb …
Unpacking nvidia-l4t-kernel-dtbs (4.9.140-tegra-32.3.1-20200526-CTI-TX2-V003) over (4.9.140-tegra-32.3.1-20200526-CTI-TX2-V003) …
Preparing to unpack …/nvidia-l4t-kernel-headers_4.9.140-tegra-32.3.1-20200526-CTI-TX2-V003_arm64.deb …
Unpacking nvidia-l4t-kernel-headers (4.9.140-tegra-32.3.1-20200526-CTI-TX2-V003) over (4.9.140-tegra-32.3.1-20200526-CTI-TX2-V003) …
Preparing to unpack …/nvidia-l4t-bootloader_32.3.1-20191209230245_arm64.deb …
Pre-installing bootloader package, skip flashing
Unpacking nvidia-l4t-bootloader (32.3.1-20191209230245) over (32.3.1-20191209230245) …
Setting up jetson-gpio-common (2.0.4) …
Setting up python-jetson-gpio (2.0.4) …
Setting up nvidia-l4t-apt-source (32.3.1-20191209230245) …
Pre-installing… skip changing source list.
Setting up nvidia-l4t-configs (32.3.1-20191209230245) …
Setting up nvidia-l4t-core (32.3.1-20191209230245) …
Setting up nvidia-l4t-firmware (32.3.1-20191209230245) …
Setting up nvidia-l4t-init (32.3.1-20191209230245) …
Setting up nvidia-l4t-multimedia-utils (32.3.1-20191209230245) …
Setting up nvidia-l4t-oem-config (32.3.1-20191209230245) …
Setting up nvidia-l4t-tools (32.3.1-20191209230245) …
Setting up nvidia-l4t-wayland (32.3.1-20191209230245) …
Setting up nvidia-l4t-weston (32.3.1-20191209230245) …
Setting up nvidia-l4t-x11 (32.3.1-20191209230245) …
Setting up nvidia-l4t-xusb-firmware (32.3.1-20191209230245) …
Pre-installing xusb firmware package, skip flashing
Setting up nvidia-l4t-kernel (4.9.140-tegra-32.3.1-20200526-CTI-TX2-V003) …
Setting up nvidia-l4t-kernel-dtbs (4.9.140-tegra-32.3.1-20200526-CTI-TX2-V003) …
Setting up nvidia-l4t-kernel-headers (4.9.140-tegra-32.3.1-20200526-CTI-TX2-V003) …
Unpacking kernel headers…
Setting up nvidia-l4t-bootloader (32.3.1-20191209230245) …
Setting up nvidia-l4t-3d-core (32.3.1-20191209230245) …
Setting up nvidia-l4t-cuda (32.3.1-20191209230245) …
Setting up nvidia-l4t-graphics-demos (32.3.1-20191209230245) …
Setting up nvidia-l4t-initrd (32.3.1-20191209230245) …
Setting up nvidia-l4t-jetson-io (4.9.140-tegra-32.3.1-20200526-CTI-TX2-V003) …
Setting up nvidia-l4t-multimedia (32.3.1-20191209230245) …
Setting up nvidia-l4t-camera (32.3.1-20191209230245) …
Setting up nvidia-l4t-gstreamer (32.3.1-20191209230245) …
Processing triggers for nvidia-l4t-kernel (4.9.140-tegra-32.3.1-20200526-CTI-TX2-V003) …
Processing triggers for libc-bin (2.27-3ubuntu1) …
Errors were encountered while processing:
CTI-L4T-V003 Installed!
end of log
I had previously installed the V002 version on another Jetson TX2 using the same host Ubuntu 16.04 laptop without issue. Any insights into what is going on or how to fix?
Much thanks,
Peter Furey
Hi Peter,
Please see CTI’s reply:
I encounter the same errors when trying to run install.sh on Ubuntu 16.04.
Additional dependencies are required for V003 that were not required for V002.
Therefore, Ubuntu 18.04 is required to install V003.
