Jetpack 4.3 fails to install on Xavier
After updating to Jetpack 4.3, I cannot flash the Xavier do to download errors. The terminal show errors with qemu
Err:1 http://security.ubuntu.com/ubuntu xenial-security/universe amd64 qemu-user-static amd64 1:2.5+dfsg-5ubuntu10.39
The amd64 package doesn’t seem to be available
Hi richtark,
Please run below commands on you host Ubuntu system:
$ sudo apt-get update
$ sudo apt-get install qemu-user-static
Then run the sdkmanager again. Thanks!
Unfortunately this does not work. Is there a repo I’m missing?
rich@demolaptop02:~/Downloads$ sudo apt-get install qemu-user-static --fix-missing
Reading package lists… Done
Building dependency tree
Reading state information… Done
The following NEW packages will be installed:
qemu-user-static
0 upgraded, 1 newly installed, 0 to remove and 372 not upgraded.
Need to get 7,761 kB of archives.
After this operation, 85.9 MB of additional disk space will be used.
404 Not Found [IP: 91.189.91.14 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/universe/q/qemu/qemu-user-static_2.5+dfsg-5ubuntu10.39_amd64.deb 404 Not Found [IP: 91.189.91.14 80]
E: Internal Error, ordering was unable to handle the media swap
Hi richtark,
You can reference Topic-1067696.
The referenced link fixed the qemu issue.
Steps to resolve for me
sudo dpkg --force-architecture --remove-architecture “arm64”
sudo echo “deb http://security.ubuntu.com/ubuntu xenial-security main universe” >>/etc/apt/sources.lst
sudo apt-get update
