Error occurs when i install Jatson SDK components. Error log as follows:
18:10:26 ERROR : Flash Jetson AGX Xavier : Board ID(2888) version(400) sku(0001) revision(J.0)
18:19:23 ERROR : Flash Jetson AGX Xavier :
18:19:23 ERROR : Flash Jetson AGX Xavier : 2: RAW: 2158592( 527 blks) ==> 4272180:2158604
18:19:23 ERROR : Flash Jetson AGX Xavier : 3: SKP: 31395840( 7665 blks) ==> 6430784:12
18:19:23 ERROR : Flash Jetson AGX Xavier : 4: RAW: 7376896( 1801 blks) ==> 6430796:7376908
18:19:23 ERROR : Flash Jetson AGX Xavier : 5: SKP: 88956928( 21718 blks) ==> 13807704:12
18:19:23 ERROR : Flash Jetson AGX Xavier : 7: SKP: 4456448( 1088 blks) ==> 13820016:12
18:19:23 ERROR : Flash Jetson AGX Xavier : 8: RAW: 573440( 140 blks) ==> 13820028:573452
18:19:23 ERROR : Flash Jetson AGX Xavier : 9: SKP: 69632( 17 blks) ==> 14393480:12
18:19:23 ERROR : Flash Jetson AGX Xavier : 10: RAW: 716800( 175 blks) ==> 14393492:716812
18:19:23 ERROR : Flash Jetson AGX Xavier : 11: SKP: 69632( 17 blks) ==> 15110304:12
18:21:56 ERROR : Flash Jetson AGX Xavier : 5193: SKP: 1778384896( 434176 blks) ==> 4572017544:12
18:21:56 ERROR : Flash Jetson AGX Xavier : – Total: ---------------------------------------------------
18:42:19 ERROR : command terminated with error
18:42:19 ERROR : failed to query component: NV_L4T_CUDA_TARGET_POST_INSTALL_COMP version: 10.0 for bundle:
18:42:20 ERROR : command terminated with error
18:42:20 ERROR : failed to query component: NV_L4T_CUDNN_TARGET_POST_INSTALL_COMP version: 7.6 for bundle:
18:42:21 ERROR : command terminated with error
18:42:21 ERROR : failed to query component: NV_L4T_TENSORRT_DLA_TARGET_POST_INSTALL_COMP version: 6.0 for bundle:
18:42:22 ERROR : command terminated with error
18:42:22 ERROR : failed to query component: NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP version: 4.1.1 for bundle:
18:42:25 ERROR : command terminated with error
18:42:25 ERROR : failed to query component: NV_L4T_VISIONWORKS_TARGET_POST_INSTALL_COMP version: 1.6 for bundle:
18:42:26 ERROR : command terminated with error
18:42:26 ERROR : failed to query component: NV_VPI_TARGET_POST_INSTALL_COMP version: 0.1.0 for bundle:
18:42:27 ERROR : command terminated with error
18:42:27 ERROR : failed to query component: NV_DOCKER_TARGET_POST_INSTALL_COMP version: 0.9.0 for bundle:
18:42:28 ERROR : command terminated with error
18:42:28 ERROR : failed to query component: NV_MULTIMEDIA_API_TARGET_POST_INSTALL_T194_COMP version: 32.3 for bundle:
18:42:29 ERROR : command terminated with error
18:42:29 ERROR : failed to query component: NV_DEEPSTREAM_TARGET_POST_INSTALL_COMP version: 4.0.2 for bundle:
18:42:34 ERROR : CUDA Toolkit for L4T : scp: /opt/nvidia/deb_repos/: Permission denied
18:42:34 ERROR : CUDA Toolkit for L4T : : Scp deb file to target failed. Command scp -F /dev/null -o PubkeyAuthentication=no -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no -o ConnectTimeout=5 -r ‘/home/zhaobo/workspace/sdkmanager/nvidia/sdkm_downloads/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb’ zhaobo@192.168.55.1:/opt/nvidia/deb_repos/ finished with error
18:42:34 ERROR : CUDA Toolkit for L4T : command terminated with error
18:42:34 ERROR : CUDA Toolkit for L4T : install ‘CUDA Toolkit for L4T’ failure, command < cd ‘/home/zhaobo/workspace/sdkmanager/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888’ ; ‘/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter’ -a=‘install’ -c=‘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’ -i=‘NV_L4T_CUDA_TARGET_POST_INSTALL_COMP’ -v=‘10.0’ -l=‘/home/zhaobo/workspace/sdkmanager/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888’ -L=‘/home/zhaobo/.nvsdkm/logs/JetPack_4.3_Linux’ -p=‘5502’ -t=‘P2888’ -e=‘/home/zhaobo/workspace/sdkmanager/nvidia/sdkm_downloads/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb’ > terminated with error
18:42:37 ERROR : NVIDIA Container Runtime with Docker integration (Beta) : scp: /opt/nvidia/deb_repos/: Permission denied
18:42:37 ERROR : NVIDIA Container Runtime with Docker integration (Beta) : : Scp deb file to target failed. Command scp -F /dev/null -o PubkeyAuthentication=no -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no -o ConnectTimeout=5 -r ‘/home/zhaobo/workspace/sdkmanager/nvidia/sdkm_downloads/nvidia-container-csv-cuda_10.0.326-1_arm64.deb’ zhaobo@192.168.55.1:/opt/nvidia/deb_repos/ finished with error
18:42:37 ERROR : NVIDIA Container Runtime with Docker integration (Beta) : command terminated with error
18:42:37 ERROR : NVIDIA Container Runtime with Docker integration (Beta) : install ‘NVIDIA Container Runtime with Docker integration (Beta)’ failure, command < cd ‘/home/zhaobo/workspace/sdkmanager/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888’ ; ‘/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter’ -a=‘install’ -c=‘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’ -i=‘NV_DOCKER_TARGET_POST_INSTALL_COMP’ -v=‘0.9.0’ -l=‘/home/zhaobo/workspace/sdkmanager/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888’ -L=‘/home/zhaobo/.nvsdkm/logs/JetPack_4.3_Linux’ -p=‘5502’ -t=‘P2888’ -e=‘/home/zhaobo/workspace/sdkmanager/nvidia/sdkm_downloads/libnvidia-container-tools_0.9.0_beta.1_arm64.deb’ > terminated with error
18:42:37 ERROR : Unavailable components detected, please check log
18:42:37 ERROR : cuDNN on Target : cuDNN on Target Skipped. Due to its dependencies fail to install: CUDA Toolkit for L4T,
18:42:37 ERROR : TensorRT on Target : TensorRT on Target Skipped. Due to its dependencies fail to install: CUDA Toolkit for L4T,
18:42:37 ERROR : OpenCV on Target : OpenCV on Target Skipped. Due to its dependencies fail to install: CUDA Toolkit for L4T,
18:42:37 ERROR : VisionWorks on Target : VisionWorks on Target Skipped. Due to its dependencies fail to install: CUDA Toolkit for L4T,
18:42:37 ERROR : VPI : VPI Skipped. Due to its dependencies fail to install: CUDA Toolkit for L4T,
18:42:37 ERROR : Multimedia API : Multimedia API Skipped. Due to its dependencies fail to install: CUDA Toolkit for L4T,
18:42:37 ERROR : DeepStream : DeepStream Skipped. Due to its dependencies fail to install: CUDA Toolkit for L4T,
