[JetPack 4.3 - L4T R32.3.1 ] Whole system goes dead when connecting VPN
Dear experts,
I have just setup my Jetson Nano with the latest JetPack 4.3. And I am trying to connect a VPN. But after I click connect after input the password in the VPN Authentication popup, after couple of seconds, the whole system goes dead. No clicks or keystrokes can work. Even the remote SSH session is frozen as well. Not sure how to fix that…
I also copy the syslog below. The deadness happened at around 19:59 and then after couple of minutes’ freezing time, I re-pluged the power adapter.
Much appreciated for your kind help.
Feb 19 19:58:50 kun-desktop dbus-daemon[6159]: [session uid=1000 pid=6159] Activating service name=‘org.freedesktop.portal.IBus’ requested by ‘:1.56’ (uid=1000 pid=7014 comm="/usr/bin/ibus-daemon --replace --panel disable --x")
Feb 19 19:58:50 kun-desktop dbus-daemon[6159]: [session uid=1000 pid=6159] Successfully activated service ‘org.freedesktop.IBus’
Feb 19 19:58:50 kun-desktop dbus-daemon[6159]: [session uid=1000 pid=6159] Successfully activated service ‘org.gtk.vfs.UDisks2VolumeMonitor’
Feb 19 19:58:50 kun-desktop systemd[6115]: Started Virtual filesystem service - disk device monitor.
Feb 19 19:58:50 kun-desktop dbus-daemon[6159]: [session uid=1000 pid=6159] Activating via systemd: service name=‘org.gtk.vfs.GoaVolumeMonitor’ unit=‘gvfs-goa-volume-monitor.service’ requested by ‘:1.52’ (uid=1000 pid=6987 comm="/usr/lib/unity-settings-daemon/unity-fallback-moun")
Feb 19 19:58:50 kun-desktop systemd[6115]: Starting Virtual filesystem service - GNOME Online Accounts monitor…
Feb 19 19:58:50 kun-desktop dbus-daemon[6159]: [session uid=1000 pid=6159] Successfully activated service ‘org.freedesktop.portal.IBus’
Feb 19 19:58:50 kun-desktop dbus-daemon[6159]: [session uid=1000 pid=6159] Successfully activated service ‘org.gtk.vfs.GoaVolumeMonitor’
Feb 19 19:58:51 kun-desktop systemd[6115]: Started Virtual filesystem service - GNOME Online Accounts monitor.
Feb 19 19:58:51 kun-desktop dbus-daemon[6159]: [session uid=1000 pid=6159] Activating via systemd: service name=‘org.gtk.vfs.GPhoto2VolumeMonitor’ unit=‘gvfs-gphoto2-volume-monitor.service’ requested by ‘:1.52’ (uid=1000 pid=6987 comm="/usr/lib/unity-settings-daemon/unity-fallback-moun")
Feb 19 19:58:51 kun-desktop systemd[6115]: Starting Virtual filesystem service - digital camera monitor…
Feb 19 19:58:51 kun-desktop compiz[6946]: /usr/bin/compiz (core) - Info: Starting plugin: unityshell
Feb 19 19:58:51 kun-desktop dbus-daemon[6159]: [session uid=1000 pid=6159] Successfully activated service ‘org.gtk.vfs.GPhoto2VolumeMonitor’
Feb 19 19:58:51 kun-desktop systemd[6115]: Started Virtual filesystem service - digital camera monitor.
Feb 19 19:58:51 kun-desktop dbus-daemon[6159]: [session uid=1000 pid=6159] Activating via systemd: service name=‘org.gtk.vfs.AfcVolumeMonitor’ unit=‘gvfs-afc-volume-monitor.service’ requested by ‘:1.52’ (uid=1000 pid=6987 comm="/usr/lib/unity-settings-daemon/unity-fallback-moun")
Feb 19 19:58:51 kun-desktop systemd[6115]: Starting Virtual filesystem service - Apple File Conduit monitor…
Feb 19 19:58:51 kun-desktop dbus-daemon[6159]: [session uid=1000 pid=6159] Activating service name=‘org.freedesktop.FileManager1’ requested by ‘:1.55’ (uid=1000 pid=6994 comm=“nautilus-desktop “)
Feb 19 19:58:51 kun-desktop gvfs-afc-volume-monitor[7065]: Volume monitor alive
Feb 19 19:58:51 kun-desktop dbus-daemon[6159]: [session uid=1000 pid=6159] Successfully activated service ‘org.gnome.evolution.dataserver.Calendar7’
Feb 19 19:58:51 kun-desktop systemd[6115]: Started Evolution calendar service.
Feb 19 19:58:51 kun-desktop dbus-daemon[6159]: [session uid=1000 pid=6159] Successfully activated service ‘org.gtk.vfs.AfcVolumeMonitor’
Feb 19 19:58:51 kun-desktop systemd[6115]: Started Virtual filesystem service - Apple File Conduit monitor.
Feb 19 19:58:51 kun-desktop dbus-daemon[6159]: [session uid=1000 pid=6159] Activating via systemd: service name=‘org.gtk.vfs.MTPVolumeMonitor’ unit=‘gvfs-mtp-volume-monitor.service’ requested by ‘:1.52’ (uid=1000 pid=6987 comm=”/usr/lib/unity-settings-daemon/unity-fallback-moun”)
Feb 19 19:58:51 kun-desktop systemd[6115]: Starting Virtual filesystem service - Media Transfer Protocol monitor…
Feb 19 19:58:51 kun-desktop dbus-daemon[6159]: [session uid=1000 pid=6159] Successfully activated service ‘org.gtk.vfs.MTPVolumeMonitor’
Feb 19 19:58:51 kun-desktop systemd[6115]: Started Virtual filesystem service - Media Transfer Protocol monitor.
Feb 19 19:58:51 kun-desktop nm-applet[7001]: Can’t set a parent on widget which has a parent
Feb 19 19:58:51 kun-desktop dbus-daemon[6159]: [session uid=1000 pid=6159] Successfully activated service ‘org.freedesktop.FileManager1’
Feb 19 19:58:51 kun-desktop compiz[6946]: compizconfig - Info: Backend : gsettings
Feb 19 19:58:51 kun-desktop compiz[6946]: compizconfig - Info: Integration : true
Feb 19 19:58:51 kun-desktop compiz[6946]: compizconfig - Info: Profile : unity
Feb 19 19:58:51 kun-desktop compiz[6946]: WARN 2020-02-19 19:58:51 unity.glib.dbus.server GLibDBusServer.cpp:593 Can’t register object ‘org.gnome.Shell’ yet as we don’t have a connection, waiting for it…
Feb 19 19:58:51 kun-desktop compiz[6946]: WARN 2020-02-19 19:58:51 unity.debug.interface DebugDBusInterface.cpp:217 Unable to load entry point in libxpathselect: libxpathselect.so.1.4: cannot open shared object file: No such file or directory – full D-Bus introspection will not be available
Feb 19 19:58:51 kun-desktop compiz[6946]: WARN 2020-02-19 19:58:51 unity.glib.dbus.server GLibDBusServer.cpp:593 Can’t register object ‘org.gnome.SessionManager.EndSessionDialog’ yet as we don’t have a connection, waiting for it…
Feb 19 19:58:51 kun-desktop compiz[6946]: WARN 2020-02-19 19:58:51 xim.controller XIMController.cpp:103 IBus natively supported.
Feb 19 19:58:51 kun-desktop compiz[6946]: WARN 2020-02-19 19:58:51 unity.dash.gsettingsscopereader GSettingsScopes.cpp:108 Error fetching protocol metadata for scope: social.scope : Valid key file could not be found in search dirs
Feb 19 19:58:52 kun-desktop compiz[6946]: WARN 2020-02-19 19:58:52 unity.glib.dbus.server GLibDBusServer.cpp:593 Can’t register object ‘com.canonical.Unity.Launcher’ yet as we don’t have a connection, waiting for it…
Feb 19 19:58:52 kun-desktop dbus-daemon[6159]: [session uid=1000 pid=6159] Activating via systemd: service name=‘org.gnome.evolution.dataserver.AddressBook9’ unit=‘evolution-addressbook-factory.service’ requested by ‘:1.70’ (uid=1000 pid=7074 comm="/usr/lib/evolution/evolution-calendar-factory-subp")
Feb 19 19:58:52 kun-desktop systemd[6115]: Starting Evolution address book service…
Feb 19 19:58:52 kun-desktop compiz[6946]: WARN 2020-02-19 19:58:52 unity.glib.dbus.server GLibDBusServer.cpp:593 Can’t register object ‘com.canonical.Unity.Dash’ yet as we don’t have a connection, waiting for it…
Feb 19 19:58:52 kun-desktop dbus-daemon[6159]: [session uid=1000 pid=6159] Successfully activated service ‘org.gnome.evolution.dataserver.AddressBook9’
Feb 19 19:58:52 kun-desktop systemd[6115]: Started Evolution address book service.
Feb 19 19:58:52 kun-desktop compiz[6946]: WARN 2020-02-19 19:58:52 unity.glib.dbus.server GLibDBusServer.cpp:593 Can’t register object ‘com.canonical.Unity.Session’ yet as we don’t have a connection, waiting for it…
Feb 19 19:58:52 kun-desktop compiz[6946]: WARN 2020-02-19 19:58:52 unity.glib.dbus.server GLibDBusServer.cpp:593 Can’t register object ‘org.gnome.ScreenSaver’ yet as we don’t have a connection, waiting for it…
Feb 19 19:58:52 kun-desktop gnome-screensav[6786]: Lost the name, shutting down.
Feb 19 19:58:52 kun-desktop unity-settings-[6737]: Grab failed for some keys, another application may already have access the them.
Feb 19 19:58:52 kun-desktop compiz[6946]: ERROR 2020-02-19 19:58:52 unity.glib.dbus.server GLibDBusServer.cpp:538 DBus name lost ‘org.gnome.Shell’
Feb 19 19:58:52 kun-desktop compiz[6946]: ERROR 2020-02-19 19:58:52 unity.glib.dbus.server GLibDBusServer.cpp:538 DBus name lost ‘com.canonical.Unity’
Feb 19 19:58:53 kun-desktop unity-panel-ser[6957]: window_menu_model_new: assertion ‘BAMF_IS_APPLICATION(app)’ failed
Feb 19 19:58:53 kun-desktop unity-panel-ser[6957]: track_menus: assertion ‘IS_WINDOW_MENU(menus)’ failed
Feb 19 19:58:54 kun-desktop dbus-daemon[6159]: [session uid=1000 pid=6159] Activating via systemd: service name=‘org.gtk.vfs.Metadata’ unit=‘gvfs-metadata.service’ requested by ‘:1.55’ (uid=1000 pid=6994 comm="nautilus-desktop “)
Feb 19 19:58:54 kun-desktop systemd[6115]: Starting Virtual filesystem metadata service…
Feb 19 19:58:54 kun-desktop dbus-daemon[6159]: [session uid=1000 pid=6159] Successfully activated service ‘org.gtk.vfs.Metadata’
Feb 19 19:58:54 kun-desktop systemd[6115]: Started Virtual filesystem metadata service.
Feb 19 19:58:57 kun-desktop wpa_supplicant[4108]: wlan0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-40 noise=9999 txrate=400000
Feb 19 19:59:00 kun-desktop NetworkManager[4101]: [1582113540.1707] manager: NetworkManager state is now CONNECTED_GLOBAL
Feb 19 19:59:00 kun-desktop dbus-daemon[3870]: [system] Activating via systemd: service name=‘org.freedesktop.nm_dispatcher’ unit=‘dbus-org.freedesktop.nm-dispatcher.service’ requested by ‘:1.10’ (uid=0 pid=4101 comm=”/usr/sbin/NetworkManager --no-daemon ")
Feb 19 19:59:00 kun-desktop systemd[1]: Starting Network Manager Script Dispatcher Service…
Feb 19 19:59:00 kun-desktop whoopsie[4669]: [19:59:00] The default IPv4 route is: /org/freedesktop/NetworkManager/ActiveConnection/1
Feb 19 19:59:00 kun-desktop nm-applet[7001]: gtk_widget_destroy: assertion ‘GTK_IS_WIDGET (widget)’ failed
Feb 19 19:59:00 kun-desktop whoopsie[4669]: [19:59:00] Not a paid data plan: /org/freedesktop/NetworkManager/ActiveConnection/1
Feb 19 19:59:00 kun-desktop whoopsie[4669]: [19:59:00] Found usable connection: /org/freedesktop/NetworkManager/ActiveConnection/1
Feb 19 19:59:00 kun-desktop dbus-daemon[3870]: [system] Successfully activated service ‘org.freedesktop.nm_dispatcher’
Feb 19 19:59:00 kun-desktop systemd[1]: Started Network Manager Script Dispatcher Service.
Feb 19 19:59:00 kun-desktop nm-dispatcher: req:1 ‘connectivity-change’: new request (1 scripts)
Feb 19 19:59:00 kun-desktop nm-dispatcher: req:1 ‘connectivity-change’: start running ordered scripts…
Feb 19 19:59:00 kun-desktop nm-applet[7001]: Can’t set a parent on widget which has a parent
Feb 19 19:59:01 kun-desktop whoopsie[4669]: [19:59:01] online
Feb 19 19:59:01 kun-desktop compiz[6946]: WARN 2020-02-19 19:59:01 unity.filemanager.gnome GnomeFileManager.cpp:69 Locations have been invalidated, maybe there’s no filemanager around…
Feb 19 19:59:10 kun-desktop dbus-daemon[6159]: [session uid=1000 pid=6159] Activating via systemd: service name=‘org.gnome.zeitgeist.Engine’ unit=‘zeitgeist.service’ requested by ‘:1.74’ (uid=1000 pid=7192 comm="zeitgeist-datahub “)
Feb 19 19:59:10 kun-desktop systemd[6115]: Starting Zeitgeist activity log service…
Feb 19 19:59:10 kun-desktop dbus-daemon[6159]: [session uid=1000 pid=6159] Activating via systemd: service name=‘org.gnome.zeitgeist.SimpleIndexer’ unit=‘zeitgeist-fts.service’ requested by ‘:1.75’ (uid=1000 pid=7201 comm=”/usr/bin/zeitgeist-daemon ")
Feb 19 19:59:10 kun-desktop dbus-daemon[6159]: [session uid=1000 pid=6159] Successfully activated service ‘org.gnome.zeitgeist.Engine’
Feb 19 19:59:10 kun-desktop systemd[6115]: Started Zeitgeist activity log service.
Feb 19 19:59:10 kun-desktop systemd[6115]: Starting Zeitgeist full-text search indexer…
Feb 19 19:59:10 kun-desktop zeitgeist-daemon[7201]: #033[31m[11:59:10.439316 WARNING]#033[0m zeitgeist-daemon.vala:127: Unable to parse version info!
Feb 19 19:59:10 kun-desktop zeitgeist-daemon[7201]: #033[31m[11:59:10.440715 WARNING]#033[0m zeitgeist-daemon.vala:127: Unable to parse version info!
Feb 19 19:59:10 kun-desktop dbus-daemon[6159]: [session uid=1000 pid=6159] Successfully activated service ‘org.gnome.zeitgeist.SimpleIndexer’
Feb 19 19:59:10 kun-desktop systemd[6115]: Started Zeitgeist full-text search indexer.
Feb 19 19:59:10 kun-desktop zeitgeist-daemon[7201]: #033[31m[11:59:10.783223 WARNING]#033[0m zeitgeist-daemon.vala:127: Unable to parse version info!
Feb 19 19:59:10 kun-desktop zeitgeist-datah[7234]: zeitgeist-datahub.vala:227: Unable to get name “org.gnome.zeitgeist.datahub” on the bus!
Feb 19 20:36:10 kun-desktop systemd-timesyncd[3581]: Synchronized to time server 94.23.2.80:123 (0.fr.pool.ntp.org).
Feb 19 20:36:10 kun-desktop systemd[1]: Started Run anacron jobs.
Feb 19 20:36:10 kun-desktop anacron[7250]: Anacron 2.3 started on 2020-02-19
Feb 19 20:36:10 kun-desktop anacron[7250]: Normal exit (0 jobs run)
Feb 19 20:36:24 kun-desktop systemd[1]: Started Session 4 of user kun.
@lb_0574
Could you try another desktop? Just for a quick confirm.
sudo apt install xfce4
And try again with the VPN connection to see what happened.
