[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-4164) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Wed Apr 8 18:10:49 PDT 2020
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] Found tegra_fbmem: 00800000@92cb4000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb0_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] On node 0 totalpages: 1039872
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519168 pages, LIFO batch:31
[ 0.000000] Normal zone: 8136 pages used for memmap
[ 0.000000] Normal zone: 520704 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc0fefb1000 s61656 r8192 d32552 u102400
[ 0.000000] pcpu-alloc: s61656 r8192 d32552 u102400 alloc=25*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 tegra_fbmem=0x800000@0x92cb4000 is_hdmi_initialised=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29392(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3562148K/4159488K available (15294K kernel code, 2934K rwdata, 6636K rodata, 8576K init, 609K bss, 122204K reserved, 475136K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f70000 ( 15296 KB)
[ 0.000000] .rodata : 0xffffff8008f70000 - 0xffffff80095f0000 ( 6656 KB)
[ 0.000000] .init : 0xffffff80095f0000 - 0xffffff8009e50000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e50000 - 0xffffff800a12d808 ( 2935 KB)
[ 0.000000] .bss : 0xffffff800a12d808 - 0xffffff800a1c5f3c ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.001747] Console: colour dummy device 80x25
[ 0.001765] console [tty0] enabled
[ 0.001781] kmemleak: Kernel memory leak detector disabled
[ 0.001803] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=76800)
[ 0.001815] pid_max: default: 32768 minimum: 301
[ 0.002273] Security Framework initialized
[ 0.002498] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.002506] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003658] ftrace: allocating 47094 entries in 184 pages
[ 0.176006] sched-energy: CPU device node has no sched-energy-costs
[ 0.176041] ASID allocator initialised with 65536 entries
[ 0.212353] tegra-id: chipid=22117.
[ 0.212366] tegra-id: opt_subrevision=0.
[ 0.212384] Tegra Speedo/IDDQ fuse revision 4
[ 0.212388] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.212393] Tegra: CPU Process ID 0, SoC Process ID 1, GPU Process ID 0
[ 0.212399] Tegra: CPU Speedo Value 2043, SoC Speedo Value 1951, GPU Speedo Value 2038
[ 0.212403] Tegra: CPU IDDQ Value 2192, SoC IDDQ Value 2436, GPU IDDQ Value 2815
[ 0.212421] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 1
[ 0.212439] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
[ 0.212448] DTB Build time: Apr 8 2020 18:15:57
[ 0.261097] CPU1: Booted secondary processor [411fd071]
[ 0.292989] CPU2: Booted secondary processor [411fd071]
[ 0.324965] CPU3: Booted secondary processor [411fd071]
[ 0.325058] Brought up 4 CPUs
[ 0.325066] SMP: Total of 4 processors activated.
[ 0.325074] CPU features: detected feature: 32-bit EL0 Support
[ 0.325345] CPU: All CPU(s) started at EL2
[ 0.325363] alternatives: patching kernel code
[ 0.333840] devtmpfs: initialized
[ 0.371605] Initilizing CustomIPI irq domain
[ 0.372015] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.372039] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.383487] pinctrl core: initialized pinctrl subsystem
[ 0.384165] OS set in device tree is not L4T.
[ 0.384621] regulator-dummy: no parameters
[ 0.384900] Initializing plugin-manager
[ 0.385013] Plugin module not found
[ 0.385310] node /plugin-manager/fragement@0 match with board >=3448-0000-100
[ 0.385885] node /plugin-manager/fragment@1 match with board >=3448-0000-101
[ 0.387770] node /plugin-manager/fragement@10 match with board >=3448-0000-300
[ 0.390196] node /plugin-manager/fragement@11 match with board >=3448-0000-300
[ 0.393758] NET: Registered protocol family 16
[ 0.395189] pstore: using zlib compression
[ 0.395231] console [pstore-1] enabled
[ 0.395237] pstore: Registered ramoops as persistent store backend
[ 0.395242] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.409115] cpuidle: using governor menu
[ 0.413405] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.415261] vdso: 2 pages (1 code @ ffffff8008f77000, 1 data @ ffffff8009e54000)
[ 0.415282] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.417706] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.419916] Serial: AMBA PL011 UART driver
[ 0.420434] tegra_powergate_init: DONE
[ 0.420451] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
[ 0.420459] DTB Build time: Apr 8 2020 18:15:57
[ 0.422481] Tegra reboot handler registered.
[ 0.427071] iommu: Adding device tegra-carveouts to group 0
[ 0.427223] platform tegra-carveouts: domain=ffffffc0f9b9b3d8 allocates as[0]=ffffffc0f9bcc0a8
[ 0.427594] iommu: Adding device smmu_test to group 1
[ 0.427639] platform smmu_test: domain=ffffffc0f9b9b618 allocates as[0]=ffffffc0f9bcc110
[ 0.428472] mc: mapped MMIO address: 0xffffff800802e000 → 0x70019000
[ 0.428532] mc: mapped MMIO address: 0xffffff8008065000 → 0x7001c000
[ 0.428586] mc: mapped MMIO address: 0xffffff8008079000 → 0x7001d000
[ 0.428597] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.428618] mc-err: mcerr ops are set to t21x
[ 0.438377] iommu: Adding device 70090000.xusb to group 2
[ 0.438666] iommu: Adding device 70006000.serial to group 3
[ 0.438753] platform 70006000.serial: domain=ffffffc0f94bc618 allocates as[0]=ffffffc0f9bcc178
[ 0.439186] iommu: Adding device 70006040.serial to group 4
[ 0.439459] iommu: Adding device 70006200.serial to group 5
[ 0.439682] iommu: Adding device sound to group 6
[ 0.439728] platform sound: domain=ffffffc0f94bcb58 allocates as[0]=ffffffc0f9bcc1e0
[ 0.440302] iommu: Adding device 7000d400.spi to group 7
[ 0.440563] iommu: Adding device 7000d600.spi to group 8
[ 0.440837] iommu: Adding device 70410000.spi to group 9
[ 0.441216] iommu: Adding device 50000000.host1x to group 10
[ 0.441497] iommu: Adding device 54080000.vi to group 11
[ 0.441883] iommu: Adding device 54600000.isp to group 12
[ 0.442140] iommu: Adding device 54680000.isp to group 13
[ 0.442453] iommu: Adding device tegradc.0 to group 14
[ 0.442506] platform tegradc.0: domain=ffffffc0f94c9a98 allocates as[0]=ffffffc0f9bcc248
[ 0.446698] platform tegradc.0: IOVA linear map 0x0000000092cb4000(800000)
[ 0.447093] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.447429] iommu: Adding device tegradc.1 to group 15
[ 0.447477] platform tegradc.1: domain=ffffffc0f94c9cd8 allocates as[0]=ffffffc0f9bcc2b0
[ 0.451656] platform tegradc.1: IOVA linear map 0x0000000092cb4000(800000)
[ 0.452048] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.452316] iommu: Adding device 54340000.vic to group 16
[ 0.452531] iommu: Adding device 544c0000.nvenc to group 17
[ 0.452729] iommu: Adding device 54500000.tsec to group 18
[ 0.452951] iommu: Adding device 54100000.tsecb to group 19
[ 0.453188] iommu: Adding device 54480000.nvdec to group 20
[ 0.453413] iommu: Adding device 54380000.nvjpg to group 21
[ 0.454449] iommu: Adding device 546c0000.i2c to group 22
[ 0.454783] iommu: Adding device 57000000.gpu to group 23
[ 0.454835] platform 57000000.gpu: domain=ffffffc0f94d8cd8 allocates as[0]=ffffffc0f9bcc318
[ 0.454875] platform 57000000.gpu: domain=ffffffc0f94d8cd8 allocates as[1]=ffffffc0f9bcc380
[ 0.454917] platform 57000000.gpu: domain=ffffffc0f94d8cd8 allocates as[2]=ffffffc0f9bcc3e8
[ 0.454956] platform 57000000.gpu: domain=ffffffc0f94d8cd8 allocates as[3]=ffffffc0f9bcc450
[ 0.455877] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.455887] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.455898] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.455903] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.455907] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.509287] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.509297] tegra-pmc: Clear bootloader IO dpd settings
[ 0.509321] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.509390] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.509676] iommu: Adding device 70012000.se to group 24
[ 0.510524] iommu: Adding device 7000c000.i2c to group 25
[ 0.510796] iommu: Adding device 7000c400.i2c to group 26
[ 0.511142] iommu: Adding device 7000c500.i2c to group 27
[ 0.511451] iommu: Adding device 7000c700.i2c to group 28
[ 0.511761] iommu: Adding device 7000d000.i2c to group 29
[ 0.512029] iommu: Adding device 7000d100.i2c to group 30
[ 0.512378] iommu: Adding device sdhci-tegra.0 to group 31
[ 0.512438] platform sdhci-tegra.0: domain=ffffffc0f944c6d8 allocates as[0]=ffffffc0f9bcc4b8
[ 0.513450] iommu: Adding device 700d0000.xudc to group 32
[ 0.517300] vdd-ac-bat: 5000 mV
[ 0.517750] vdd-5v0-sys: 5000 mV
[ 0.518815] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.518854] vdd-5v0-hdmi: 5000 mV
[ 0.519303] vdd-1v8-sys: 1800 mV
[ 0.519743] vdd-fan: supplied by vdd-5v0-sys
[ 0.519801] vdd-fan: 5000 mV
[ 0.520274] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.520306] vdd-usb-vbus: 5000 mV
[ 0.520945] vdd-usb-vbus2: 5000 mV
[ 0.550257] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.552740] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[ 0.553904] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.553927] GPIO line 152 (camera-control-output-low) hogged as output/low
[ 0.553965] GPIO line 6 (system-suspend-gpio) hogged as output/high
[ 0.554342] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.562748] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.563115] SCSI subsystem initialized
[ 0.563343] libata version 3.00 loaded.
[ 0.563665] usbcore: registered new interface driver usbfs
[ 0.563718] usbcore: registered new interface driver hub
[ 0.563805] usbcore: registered new device driver usb
[ 0.567764] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.573093] vdd-core: 600 <–> 1162 mV at 1075 mV
[ 0.573235] random: fast init done
[ 0.574171] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.577087] vdd-ddr-1v1: 1150 mV
[ 0.580980] vdd-pre-reg-1v35: 1350 mV
[ 0.585019] vdd-1v8: 1800 mV
[ 0.589012] avdd-sys-1v2: 1200 mV
[ 0.593004] vdd-pex-1v0: 1050 mV
[ 0.593626] vddio-sdmmc-ap: 1800 <–> 3300 mV at 3300 mV
[ 0.594148] max77620-ldo3: at 3100 mV
[ 0.597013] vdd-rtc: 850 <–> 1100 mV at 1000 mV
[ 0.597596] max77620-ldo5: at 3100 mV
[ 0.601007] vddio-sdmmc3-ap: 1800 <–> 3300 mV at 2800 mV
[ 0.605009] avdd-1v05-pll: 1050 mV
[ 0.609007] avdd-io-hdmi-dp: 1050 mV
[ 0.611608] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.611881] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[ 0.612162] max77620 4-003c: max77620 probe successful
[ 0.614856] media: Linux media interface: v0.10
[ 0.614914] Linux video capture interface: v2.00
[ 0.615875] pps_core: LinuxPPS API ver. 1 registered
[ 0.615881] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.615905] PTP clock support registered
[ 0.619362] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.620303] Advanced Linux Sound Architecture Driver Initialized.
[ 0.620992] Bluetooth: Core ver 2.22
[ 0.621043] NET: Registered protocol family 31
[ 0.621047] Bluetooth: HCI device and connection manager initialized
[ 0.621065] Bluetooth: HCI socket layer initialized
[ 0.621074] Bluetooth: L2CAP socket layer initialized
[ 0.621133] Bluetooth: SCO socket layer initialized
[ 0.623022] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.623040] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.623087] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.623102] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.626780] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.628074] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.628137] vdd-3v3-sys: 3300 mV
[ 0.628444] vdd-1v8-sys: supplied by vdd-3v3-sys
[ 0.633195] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.633692] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.633734] vdd-3v3-sd: 3300 mV
[ 0.634837] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.634906] avdd-io-edp-1v05: 1050 mV
[ 0.635357] vdd-usb-hub-en: supplied by vdd-1v8-sys
[ 0.635396] vdd-usb-hub-en: 5000 mV
[ 0.636816] camchar: rtcpu character device driver loaded
[ 0.637615] extcon-gpio-states extcon:extcon@1: Cable state:1, cable id:1
[ 0.639045] clocksource: Switched to clocksource arch_sys_counter
[ 0.680761] VFS: Disk quotas dquot_6.6.0
[ 0.680890] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.681399] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.681829] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[ 0.681846] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[ 0.682070] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.682076] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.682091] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.682122] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.682127] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.682138] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.682145] nvmap_page_pool_init: Total RAM pages: 1009321
[ 0.682149] nvmap_page_pool_init: nvmap page pool size: 126165 pages (492 MB)
[ 0.682236] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.682671] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.683634] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[ 0.692367] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.692797] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.693050] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.693259] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.693431] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.693712] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.693715] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
[ 0.694161] NET: Registered protocol family 2
[ 0.695182] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.695395] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.695929] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.696086] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.696170] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.696603] NET: Registered protocol family 1
[ 0.697360] RPC: Registered named UNIX socket transport module.
[ 0.697365] RPC: Registered udp transport module.
[ 0.697368] RPC: Registered tcp transport module.
[ 0.697371] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.697385] PCI: CLS 0 bytes, default 64
[ 0.697636] Trying to unpack rootfs image as initramfs…
[ 0.930721] Freeing initrd memory: 5356K
[ 0.940962] host1x 50000000.host1x: initialized
[ 0.942823] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.946250] audit: initializing netlink subsys (disabled)
[ 0.946348] audit: type=2000 audit(0.791:1): initialized
[ 0.947173] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.957300] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.958800] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.959656] 9p: Installing v9fs 9p2000 file system support
[ 0.962963] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.963433] io scheduler noop registered
[ 0.963729] io scheduler cfq registered (default)
[ 0.966409] gic 702f9000.agic: GIC IRQ controller registered
[ 0.969457] iommu: Adding device 702ef000.adsp to group 33
[ 0.978798] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[ 0.978962] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 0.979629] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x7a47413
[ 0.979637] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 0.981273] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 0.981377] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 0.981498] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 0.981686] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 0.981774] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 0.981865] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 0.981953] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 0.982045] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 0.982131] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 0.982216] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 0.988438] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 0.990170] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 0.992153] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ 0.993443] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[ 0.993809] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[ 0.995216] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ 0.995269] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.995523] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[ 0.995779] Adding domain tsec-pd to PM domain host1x-pd
[ 0.999202] tsec 54500000.tsec: initialized
[ 1.000627] tsec 54100000.tsecb: initialized
[ 1.001341] Adding domain nvdec-pd to PM domain host1x-pd
[ 1.004941] nvdec 54480000.nvdec: initialized
[ 1.006028] Adding domain vic03-pd to PM domain host1x-pd
[ 1.006208] Adding domain msenc-pd to PM domain host1x-pd
[ 1.006376] Adding domain nvjpg-pd to PM domain host1x-pd
[ 1.010740] falcon 54340000.vic: initialized
[ 1.012040] falcon 544c0000.nvenc: initialized
[ 1.013417] falcon 54380000.nvjpg: initialized
[ 1.017870] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015FFF irq=97
[ 1.017915] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[ 1.017949] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[ 1.018136] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 1.018240] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[ 1.018245] tegra_cec 70015000.tegra_cec: probed
[ 1.018256] display board info: id 0x0, fab 0x0
[ 1.018326] generic_infoframe_type: 0x87
[ 1.018479] tegradc tegradc.0: DT parsed successfully
[ 1.018524] tegradc tegradc.0: Display dc.ffffff800ab80000 registered with id=0
[ 1.019075] tegradc tegradc.0: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350781
[ 1.026452] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 1.027283] tegradc tegradc.0: probed
[ 1.033329] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 channels
[ 1.034808] tegra-fuse-burn 7000f800.efuse:efuse-burn: shutdown limit check disabled
[ 1.034820] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 1.035363] kfuse 7000fc00.kfuse: initialized
[ 1.037062] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 1.038178] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.039741] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 1.039762] vdd-cpu: 708 <–> 1322 mV at 708 mV
[ 1.040289] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 1.041939] vdd-gpu: applied init 1000000uV constraint
[ 1.041948] vdd-gpu: 708 <–> 1323 mV at 997 mV
[ 1.042425] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 1.047641] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.047810] No Device Node present for smmu client: serial8250 !!
[ 1.047825] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.047888] iommu: Adding device serial8250 to group 35
[ 1.051589] console [ttyS0] disabled
[ 1.051724] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 1.051910] console [ttyS0] enabled
[ 1.053365] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 1.053788] serial-tegra 70006200.serial: RX in PIO mode
[ 1.053903] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 1.054912] [drm] Initialized
[ 1.060059] Console: switching to colour frame buffer device 240x67
[ 1.060251] tegradc tegradc.0: fb registered
[ 1.066476] brd: module loaded
[ 1.067940] tegradc tegradc.0: DC initialized, skipping tegra_dc_program_mode.
[ 1.067992] tegradc tegradc.0: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_75m_150m
[ 1.068534] tegradc tegradc.0: hdmi: get RGB quant from REG programmed by BL.
[ 1.068548] tegradc tegradc.0: hdmi: get YCC quant from REG programmed by BL.
[ 1.072294] loop: module loaded
[ 1.072409] tegra_profiler: version: 1.141, samples/io: 48/28
[ 1.072539] tegra_profiler: auth: init
[ 1.073884] THERMAL EST: found 2 subdevs
[ 1.073893] THERMAL EST num_resources: 0
[ 1.073900] [THERMAL EST subdev 0]
[ 1.073908] [THERMAL EST subdev 1]
[ 1.074440] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 1.074443] THERMAL EST: thz register success.
[ 1.074608] THERMAL EST: end of probe, return err: 0
[ 1.075898] sd: No Scsi addr parsed to reserve index
[ 1.075943] hisi_sas: driver version v1.6
[ 1.080814] tegra-qspi 70410000.spi: Prod settings list not found
[ 1.081999] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[ 1.082009] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
[ 1.085183] libphy: Fixed MDIO Bus: probed
[ 1.086169] tun: Universal TUN/TAP device driver, 1.6
[ 1.086177] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 1.087293] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.087300] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.087361] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.087365] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.087412] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.087416] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.087465] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.087469] Copyright(c) 1999 - 2017 Intel Corporation.
[ 1.088719] PPP generic driver version 2.4.2
[ 1.088920] PPP BSD Compression module registered
[ 1.088927] PPP Deflate Compression module registered
[ 1.088974] PPP MPPE Compression module registered
[ 1.088981] NET: Registered protocol family 24
[ 1.089054] usbcore: registered new interface driver r8152
[ 1.089110] usbcore: registered new interface driver asix
[ 1.089157] usbcore: registered new interface driver ax88179_178a
[ 1.089200] usbcore: registered new interface driver cdc_ether
[ 1.089242] usbcore: registered new interface driver net1080
[ 1.089281] usbcore: registered new interface driver cdc_subset
[ 1.089324] usbcore: registered new interface driver zaurus
[ 1.089381] usbcore: registered new interface driver cdc_ncm
[ 1.089549] VFIO - User Level meta-driver version: 0.3
[ 1.090860] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.090883] ehci-pci: EHCI PCI platform driver
[ 1.090928] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.090941] ohci-pci: OHCI PCI platform driver
[ 1.090984] ohci-platform: OHCI generic platform driver
[ 1.094159] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 1.094996] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 1.095003] Extcon AUX1(HDMI) enable
[ 1.095178] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 1.095906] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 1.095981] tegradc tegradc.1: No lt-data, using default setting
[ 1.096009] tegradc tegradc.1: No hpd-gpio in DT
[ 1.096043] tegradc tegradc.1: DT parsed successfully
[ 1.096104] tegradc tegradc.1: Display dc.ffffff800d500000 registered with id=1
[ 1.096465] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f91cd000 id
[ 1.098307] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.098906] usbcore: registered new interface driver uas
[ 1.098984] usbcore: registered new interface driver usb-storage
[ 1.099164] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 1.099218] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.099248] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 1.099488] usbcore: registered new interface driver usbserial
[ 1.100030] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 1.100098] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 1.100321] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.100326] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.100331] usb usb1: Product: xHCI Host Controller
[ 1.100334] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.100337] usb usb1: SerialNumber: 70090000.xusb
[ 1.101118] hub 1-0:1.0: USB hub found
[ 1.101166] hub 1-0:1.0: 5 ports detected
[ 1.101817] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.101829] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 1.101955] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.102046] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.102051] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.102055] usb usb2: Product: xHCI Host Controller
[ 1.102058] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.102062] usb usb2: SerialNumber: 70090000.xusb
[ 1.102536] hub 2-0:1.0: USB hub found
[ 1.102574] hub 2-0:1.0: 4 ports detected
[ 1.103506] tegra-xudc-new 700d0000.xudc: device count: 1
[ 1.104979] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 1.104997] tegra-xudc-new 700d0000.xudc: vbus state: 1
[ 1.105019] tegra-xudc-new 700d0000.xudc: device mode on: 0
[ 1.105052] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 0
[ 1.105108] tegra-xudc-new 700d0000.xudc: active: 0 => 1
[ 1.105820] mousedev: PS/2 mouse device common for all mice
[ 1.105940] usbcore: registered new interface driver xpad
[ 1.109222] tegradc tegradc.1: probed
[ 1.109595] tegradc tegradc.1: fb registered
[ 1.112822] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.112830] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.112840] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.112856] tegradc tegradc.1: blank - powerdown
[ 1.112879] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 1.112884] Extcon DP: HPD disabled
[ 1.112889] hpd: hpd_switch 0
[ 1.112894] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.112902] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.112909] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.137028] tegradc tegradc.0: nominal-pclk:148351648 parent:148350781 div:1.0 pclk:148350781 146868084~161703244
[ 1.199108] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 1.221734] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.223889] rtc rtc1: alarm rtc device
[ 1.223902] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 1.223919] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 1.224274] i2c /dev entries driver
[ 1.225783] i2c i2c-6: Added multiplexed i2c bus 7
[ 1.226178] i2c i2c-6: Added multiplexed i2c bus 8
[ 1.226184] i2c-mux-gpio cam_i2cmux: 2 port mux on Tegra I2C adapter adapter
[ 1.226692] imx219 7-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.230530] tegradc tegradc.0: blank - powerdown
[ 1.251525] imx219 8-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.274261] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 1.274264] Extcon AUX1(HDMI) disable
[ 1.274808] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 1.274885] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.274913] imx219 8-0010: board setup failed
[ 1.274974] imx219: probe of 8-0010 failed with error -121
[ 1.276039] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 1.278061] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 1.278066] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 1.278369] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.278381] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 1.278387] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 1.278525] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.278534] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 1.278540] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 1.278689] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.278696] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 1.278701] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 1.278874] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 1.279500] tegra_aotag tegra-aotag: Registering sensor 0
[ 1.279547] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.279567] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.279583] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 1.279591] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 1.280386] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.280400] tegra_dfll_action dfll-cdev-cap: Tegra DFLL ‘cap cooling device’ registered
[ 1.280540] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.280562] tegra_dfll_action dfll-cdev-floor: Tegra DFLL ‘floor cooling device’ registered
[ 1.280925] parse_throttle_dt_data: Num cap clks = 6
[ 1.280929] parse_throttle_dt_data: clk=cclk_g type=2
[ 1.280936] parse_throttle_dt_data: clk=gpu type=4
[ 1.280956] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 1.280976] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 1.280995] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 1.280998] parse_throttle_dt_data: clk=emc type=3
[ 1.281324] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.281417] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.281527] tegra_throttle_probe: probe successful. #cdevs=4
[ 1.282146] FAN dev name: pwm-fan
[ 1.282188] FAN:gpio request success.
[ 1.282240] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 1.282473] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 1.282586] pwm_fan_driver pwm-fan: fan tach request irq success
[ 1.282594] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.282669] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.282674] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 1.282678] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 1.282682] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 1.282686] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.282689] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.282693] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.282697] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.282701] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.282705] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 1.283871] device-mapper: uevent: version 1.0.3
[ 1.284313] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 1.286989] tegra210-cpufreq cpufreq: probe()…completed
[ 1.287800] sdhci: Secure Digital Host Controller Interface driver
[ 1.287801] sdhci: Copyright(c) Pierre Ossman
[ 1.287803] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.288311] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 1.288694] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 1.288818] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[ 1.293676] tegra-se 70012000.se: tegra_se_probe: complete
[ 1.294179] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.295279] usbcore: registered new interface driver usbhid
[ 1.295281] usbhid: USB HID core driver
[ 1.297920] tegra21x_actmon 6000c800.actmon: in actmon_register()…
[ 1.298217] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 1.300013] nvpmodel: initialized successfully
[ 1.301122] usbcore: registered new interface driver snd-usb-audio
[ 1.301182] No Device Node present for smmu client: snd-soc-dummy !!
[ 1.301187] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.301204] iommu: Adding device snd-soc-dummy to group 36
[ 1.302175] tegradc tegradc.0: unblank
[ 1.326303] OPE platform probe
[ 1.326394] OPE platform probe successful
[ 1.326647] OPE platform probe
[ 1.326726] OPE platform probe successful
[ 1.335253] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 1.345088] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 1.345147] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 1.346044] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 1.346179] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 1.346186] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 1.352048] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 1.352187] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 1.352314] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 1.352444] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 1.352570] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 1.352696] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 1.352821] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 1.352946] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 1.353074] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 1.353197] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 1.365588] u32 classifier
[ 1.365590] Actions configured
[ 1.365659] Initializing XFRM netlink socket
[ 1.366364] NET: Registered protocol family 10
[ 1.367024] NET: Registered protocol family 17
[ 1.367052] NET: Registered protocol family 15
[ 1.367126] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.367175] Bluetooth: RFCOMM socket layer initialized
[ 1.367184] Bluetooth: RFCOMM ver 1.11
[ 1.367189] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.367192] Bluetooth: HIDP socket layer initialized
[ 1.367210] 9pnet: Installing 9P2000 support
[ 1.367246] Key type dns_resolver registered
[ 1.367676] Registered cp15_barrier emulation handler
[ 1.367690] Registered setend emulation handler
[ 1.368721] registered taskstats version 1
[ 1.369227] Adding domain ve2-pd to PM domain host1x-pd
[ 1.369475] Adding domain ve-pd to PM domain host1x-pd
[ 1.371560] isp 54600000.isp: initialized
[ 1.372541] isp 54680000.isp: initialized
[ 1.381049] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 1.381051] Extcon AUX1(HDMI) enable
[ 1.381365] tegradc tegradc.0: sync windows ret = 250
[ 1.382591] last reset is due to power on reset
[ 1.382593] KERNEL: PMC reset status reg: 0x0
[ 1.382669] BL: PMC reset status reg: 0x0
[ 1.382671] BL: PMIC poweroff Event Recorder: 0x40
[ 1.384167] clk_cbus_recalc_rate: no gbus parent
[ 1.384171] clk_cbus_round_rate: no gbus parent
[ 1.384173] clk_cbus_round_rate: no gbus parent
[ 1.384178] clk_cbus_recalc_rate: no gbus parent
[ 1.384273] clk_cbus_recalc_rate: no gbus parent
[ 1.384275] clk_cbus_round_rate: no gbus parent
[ 1.384277] clk_cbus_round_rate: no gbus parent
[ 1.384280] clk_cbus_recalc_rate: no gbus parent
[ 1.384964] tegra_dvfs: GPU-cap: registered
[ 1.385019] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 1.385021] tegra dvfs: vdd-core: nominal 1075mV, offset 600000uV, step 12500uV, scaling enabled
[ 1.385023] tegra dvfs: vdd-gpu: nominal 1068mV, offset 708000uV, step 10000uV, scaling enabled
[ 1.386518] tegra_dvfs: vdd-gpu-vts: registered
[ 1.387338] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS ‘floor cooling device’ registered
[ 1.387994] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS ‘cap cooling device’ registered
[ 1.388492] input: gpio-keys as /devices/gpio-keys/input/input1
[ 1.401266] extcon-disp-state extcon:disp-state: cable 51 state 1
[ 1.401268] Extcon HDMI: HPD enabled
[ 1.401282] tegradc tegradc.0: hdmi: plugged
[ 1.419131] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 1.421138] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:00:20 UTC (946688420)
[ 1.422201] vi 54080000.vi: vi_probe: ++
[ 1.423248] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 1.438592] vi 54080000.vi: initialized
[ 1.444876] vi 54080000.vi: subdev nvcsi–2 bound
[ 1.444894] vi 54080000.vi: subdev imx219 7-0010 bound
[ 1.445651] vi 54080000.vi: subdev nvcsi–1 bound
[ 1.447222] Disable partitions left on by BL
[ 1.447225] disb
[ 1.447274] bwmgr: missing cdev-type property
[ 1.447369] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.447376] DRAM derating cdev registered.
[ 1.448446] vdd-fan: disabling
[ 1.448449] vdd-usb-vbus: disabling
[ 1.448452] vdd-usb-vbus2: disabling
[ 1.448462] vddio-sdmmc3-ap: disabling
[ 1.449441] avdd-io-edp-1v05: disabling
[ 1.449444] vdd-usb-hub-en: disabling
[ 1.450509] ALSA device list:
[ 1.450512] #0: tegra-hda at 0x70038000 irq 83
[ 1.450515] #1: tegra-snd-t210ref-mobile-rt565x
[ 1.453653] Freeing unused kernel memory: 8576K
[ 1.456999] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 1.457005] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.457009] usb 1-2: Product: 4-Port USB 2.1 Hub
[ 1.457012] usb 1-2: Manufacturer: Generic
[ 1.460634] hub 1-2:1.0: USB hub found
[ 1.461753] hub 1-2:1.0: 4 ports detected
[ 1.474691] Root device found: mmcblk0p1
[ 1.537078] mmc0: hw tuning done …
[ 1.537116] mmc0: new ultra high speed SDR104 SDHC card at address 59b4
[ 1.537520] mmcblk0: mmc0:59b4 USDU1 28.3 GiB
[ 1.541266] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 1.679447] Found dev node: /dev/mmcblk0p1
[ 1.741879] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 1.742622] Rootfs mounted over mmcblk0p1
[ 1.759874] Switching from initrd to actual rootfs
[ 1.763128] usb 1-2.2: new full-speed USB device number 3 using tegra-xusb
[ 1.790671] usb 1-2.2: New USB device found, idVendor=046d, idProduct=c52b
[ 1.790677] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.790680] usb 1-2.2: Product: USB Receiver
[ 1.790683] usb 1-2.2: Manufacturer: Logitech
[ 1.829170] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 1.932657] systemd[1]: System time before build time, advancing clock.
[ 1.950670] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.962681] cgroup: cgroup2: unknown option “nsdelegate”
[ 1.985031] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 1.985796] systemd[1]: Detected architecture arm64.
[ 2.008199] systemd[1]: Set hostname to .
[ 2.043092] tegra_cec 70015000.tegra_cec: physical address: 10:00.
[ 2.107659] tegra_cec 70015000.tegra_cec: Sent res: -113.
[ 2.107663] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[ 2.109100] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 2.109109] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 2.220956] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.221163] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 2.221246] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.221266] systemd[1]: Reached target Swap.
[ 2.221306] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.222858] systemd[1]: Created slice User and Session Slice.
[ 2.223733] systemd[1]: Created slice System Slice.
[ 2.223950] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 2.240252] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.243161] tegra-pcie 1003000.pcie: link 0 down, ignoring
[ 2.265361] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 2.349459] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[ 2.349467] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.349472] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 2.349476] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 2.349481] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.349504] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ 2.349569] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.349733] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.349847] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[ 2.349871] pci 0000:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 2.349901] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 2.349921] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 2.350058] pci 0000:01:00.0: supports D1 D2
[ 2.350061] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.359147] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 2.359181] pci 0000:00:02.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[ 2.359186] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.359194] pci 0000:01:00.0: BAR 4: assigned [mem 0x13000000-0x13003fff 64bit]
[ 2.359212] pci 0000:01:00.0: BAR 2: assigned [mem 0x13004000-0x13004fff 64bit]
[ 2.359229] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 2.359237] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 2.359241] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 2.359247] pci 0000:00:02.0: bridge window [mem 0x13000000-0x130fffff]
[ 2.359608] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 2.359612] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.359618] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ 2.359724] aer 0000:00:02.0:pcie002: service driver aer loaded
[ 2.359907] r8168 0000:01:00.0: enabling device (0000 → 0003)
[ 2.359924] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 2.378053] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[ 2.378144] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 00:04:4b:e5:ab:d7 from device tree
[ 2.378625] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 2.378641] r8168 Copyright (C) 2017 Realtek NIC software team nicfae@realtek.com
This program comes with ABSOLUTELY NO WARRANTY; for details, please see http://www.gnu.org/licenses/.
This is free software, and you are welcome to redistribute it under certain conditions; see http://www.gnu.org/licenses/.
[ 2.392300] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 2.599776] systemd-journald[2000]: Received request to flush runtime journal from PID 1
[ 3.516977] random: crng init done
[ 3.520414] random: 7 urandom warning(s) missed due to ratelimiting
[ 3.735089] using random self ethernet address
[ 3.745886] using random host ethernet address
[ 4.666106] Mass Storage Function, version: 2009/09/11
[ 4.666112] LUN: removable file: (no medium)
[ 4.671353] using random self ethernet address
[ 4.680542] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 4.681678] eth0: 0xffffff800abeb000, 00:04:4b:e5:ab:d7, IRQ 407
[ 4.683417] using random host ethernet address
[ 4.735827] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 4.800396] rndis0: HOST MAC 22:60:ec:6c:56:60
[ 4.801139] rndis0: MAC 22:60:ec:6c:56:61
[ 4.808504] usb0: HOST MAC 22:60:ec:6c:56:62
[ 4.808853] usb0: MAC 22:60:ec:6c:56:63
[ 4.808885] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ 4.825822] l4tbr0: port 1(rndis0) entered blocking state
[ 4.825829] l4tbr0: port 1(rndis0) entered disabled state
[ 4.829654] device rndis0 entered promiscuous mode
[ 4.848442] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 4.853796] l4tbr0: port 2(usb0) entered blocking state
[ 4.853801] l4tbr0: port 2(usb0) entered disabled state
[ 4.854747] device usb0 entered promiscuous mode
[ 4.884709] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 5.025939] android_work: did not send uevent (0 0 (null))
[ 5.065485] android_work: sent uevent USB_STATE=CONNECTED
[ 5.073724] zram: Added device: zram0
[ 5.075513] zram: Added device: zram1
[ 5.077876] zram: Added device: zram2
[ 5.078281] zram: Added device: zram3
[ 5.082647] configfs-gadget gadget: high-speed config #1: c
[ 5.082679] tegra-xudc-new 700d0000.xudc: ep 5 (type: 3, dir: in) enabled
[ 5.082695] tegra-xudc-new 700d0000.xudc: ep 3 (type: 2, dir: in) enabled
[ 5.082711] tegra-xudc-new 700d0000.xudc: ep 2 (type: 2, dir: out) enabled
[ 5.082812] tegra-xudc-new 700d0000.xudc: ep 9 (type: 3, dir: in) enabled
[ 5.082827] tegra-xudc-new 700d0000.xudc: ep 7 (type: 2, dir: in) enabled
[ 5.082842] tegra-xudc-new 700d0000.xudc: ep 4 (type: 2, dir: out) enabled
[ 5.082877] tegra-xudc-new 700d0000.xudc: ep 15 (type: 3, dir: in) enabled
[ 5.082896] tegra-xudc-new 700d0000.xudc: ep 11 (type: 2, dir: in) enabled
[ 5.082918] tegra-xudc-new 700d0000.xudc: ep 6 (type: 2, dir: out) enabled
[ 5.082955] IPv6: ADDRCONF(NETDEV_CHANGE): rndis0: link becomes ready
[ 5.083255] android_work: sent uevent USB_STATE=CONFIGURED
[ 5.119109] zram0: detected capacity change from 0 to 518557696
[ 5.171276] Adding 506400k swap on /dev/zram0. Priority:5 extents:1 across:506400k SS
[ 5.184459] zram1: detected capacity change from 0 to 518557696
[ 5.200358] Adding 506400k swap on /dev/zram1. Priority:5 extents:1 across:506400k SS
[ 5.208214] zram2: detected capacity change from 0 to 518557696
[ 5.248454] Adding 506400k swap on /dev/zram2. Priority:5 extents:1 across:506400k SS
[ 5.255169] zram3: detected capacity change from 0 to 518557696
[ 5.274750] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 5.274757] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 5.277337] Adding 506400k swap on /dev/zram3. Priority:5 extents:1 across:506400k SS
[ 5.599471] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 5.628100] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 5.628107] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.628111] usb 2-1: Product: 4-Port USB 3.1 Hub
[ 5.628114] usb 2-1: Manufacturer: Generic
[ 5.631578] hub 2-1:1.0: USB hub found
[ 5.632378] hub 2-1:1.0: 4 ports detected
[ 5.759122] logitech-djreceiver 0003:046D:C52B.0003: hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-70090000.xusb-2.2/input2
[ 5.783118] usb 2-1: usb_suspend_both: status 0
[ 5.783262] usb usb2: usb_suspend_both: status 0
[ 5.900213] input: Logitech as /devices/70090000.xusb/usb1/1-2/1-2.2/1-2.2:1.2/0003:046D:C52B.0003/0003:046D:4055.0004/input/input2
[ 5.900578] logitech-hidpp-device 0003:046D:4055.0004: input,hidraw1: USB HID v1.11 Mouse [Logitech ] on usb-70090000.xusb-2.2:1
[ 5.906275] input: Logitech K520 as /devices/70090000.xusb/usb1/1-2/1-2.2/1-2.2:1.2/0003:046D:C52B.0003/0003:046D:2011.0005/input/input3
[ 5.906813] logitech-hidpp-device 0003:046D:2011.0005: input,hidraw2: USB HID v1.11 Keyboard [Logitech K520] on usb-70090000.xusb-2.2:2
[ 5.911992] input: Logitech as /devices/70090000.xusb/usb1/1-2/1-2.2/1-2.2:1.2/0003:046D:C52B.0003/0003:046D:4055.0006/input/input4
[ 5.912329] logitech-hidpp-device 0003:046D:4055.0006: input,hidraw3: USB HID v1.11 Mouse [Logitech ] on usb-70090000.xusb-2.2:3
[ 5.918187] input: Logitech K520 as /devices/70090000.xusb/usb1/1-2/1-2.2/1-2.2:1.2/0003:046D:C52B.0003/0003:046D:2011.0007/input/input5
[ 5.918852] logitech-hidpp-device 0003:046D:2011.0007: input,hidraw4: USB HID v1.11 Keyboard [Logitech K520] on usb-70090000.xusb-2.2:4
[ 5.924197] input: Logitech M310/M310t as /devices/70090000.xusb/usb1/1-2/1-2.2/1-2.2:1.2/0003:046D:C52B.0003/0003:046D:4031.0008/input/input6
[ 5.924666] logitech-hidpp-device 0003:046D:4031.0008: input,hidraw5: USB HID v1.11 Mouse [Logitech M310/M310t] on usb-70090000.xusb-2.2:5
[ 6.200601] input: Logitech K520 as /devices/70090000.xusb/usb1/1-2/1-2.2/1-2.2:1.2/0003:046D:C52B.0003/0003:046D:2011.0009/input/input7
[ 6.201457] logitech-hidpp-device 0003:046D:2011.0009: input,hidraw6: USB HID v1.11 Keyboard [Logitech K520] on usb-70090000.xusb-2.2:6
[ 6.775472] r8168: eth0: link up
[ 6.775520] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 8.972481] l4tbr0: port 1(rndis0) entered blocking state
[ 8.972486] l4tbr0: port 1(rndis0) entered forwarding state
[ 8.972616] IPv6: ADDRCONF(NETDEV_UP): l4tbr0: link is not ready
[ 8.972632] IPv6: ADDRCONF(NETDEV_CHANGE): l4tbr0: link becomes ready
[ 9.336699] tegradc tegradc.0: blank - powerdown
[ 9.396516] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 9.396518] Extcon AUX1(HDMI) disable
[ 9.416975] tegradc tegradc.0: unblank
[ 9.427499] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 9.427579] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 9.428595] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 9.428602] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 9.470032] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 9.470035] Extcon AUX1(HDMI) enable
[ 9.475375] tegradc tegradc.0: unblank
[ 9.475774] tegradc tegradc.1: blank - powerdown
[ 14.670562] tegradc tegradc.0: blank - powerdown
[ 14.728951] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 14.728953] Extcon AUX1(HDMI) disable
[ 14.749341] tegradc tegradc.1: blank - powerdown
[ 14.750664] tegradc tegradc.0: blank - powerdown
[ 14.750679] tegradc tegradc.0: unblank
[ 14.761297] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 14.761385] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 14.762401] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 14.762408] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 14.799179] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 14.799181] Extcon AUX1(HDMI) enable
[ 14.799583] tegradc tegradc.0: sync windows ret = 250
[ 17.072351] nvgpu: 57000000.gpu nvgpu_set_error_notifier_locked:137 [ERR] error notifier set to 8 for ch 505
[ 17.082878] nvgpu: 57000000.gpu gk20a_fifo_handle_sched_error:2531 [ERR] fifo sched ctxsw timeout error: engine=0, tsg=6, ms=400
[ 17.096004] nvgpu: 57000000.gpu gk20a_fifo_handle_mmu_fault_locked:1721 [ERR] fake mmu fault on engine 0, engine subid 0 (gpc), client 12 (rast), addr 0xb6a493e000, type 13 (region viol), access_type 0x00000001,inst_ptr 0x488ce6000
[ 17.116853] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:129 [ERR] gr_fecs_os_r : 0
[ 17.125702] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:131 [ERR] gr_fecs_cpuctl_r : 0x40
[ 17.135159] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:133 [ERR] gr_fecs_idlestate_r : 0x1
[ 17.144777] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:135 [ERR] gr_fecs_mailbox0_r : 0x0
[ 17.154466] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:137 [ERR] gr_fecs_mailbox1_r : 0x0
[ 17.164065] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:139 [ERR] gr_fecs_irqstat_r : 0x0
[ 17.173537] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:141 [ERR] gr_fecs_irqmode_r : 0x4
[ 17.183078] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:143 [ERR] gr_fecs_irqmask_r : 0x8704
[ 17.192915] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:145 [ERR] gr_fecs_irqdest_r : 0x0
[ 17.202498] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:147 [ERR] gr_fecs_debug1_r : 0x40
[ 17.212134] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:149 [ERR] gr_fecs_debuginfo_r : 0x0
[ 17.221928] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:151 [ERR] gr_fecs_ctxsw_status_1_r : 0x304
[ 17.232319] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(0) : 0x1
[ 17.242704] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(1) : 0x0
[ 17.253067] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(2) : 0x90009
[ 17.263806] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(3) : 0x14000
[ 17.274623] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(4) : 0x1ffda0
[ 17.285618] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(5) : 0x0
[ 17.295993] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(6) : 0x0
[ 17.306352] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(7) : 0x0
[ 17.316777] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(8) : 0x0
[ 17.327179] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(9) : 0x0
[ 17.337543] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(10) : 0x0
[ 17.347986] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(11) : 0x0
[ 17.358427] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(12) : 0x0
[ 17.369036] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(13) : 0x0
[ 17.379757] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(14) : 0x0
[ 17.390857] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(15) : 0x0
[ 17.401334] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:159 [ERR] gr_fecs_engctl_r : 0x0
[ 17.410832] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:161 [ERR] gr_fecs_curctx_r : 0x0
[ 17.420297] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:163 [ERR] gr_fecs_nxtctx_r : 0x0
[ 17.429841] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:169 [ERR] FECS_FALCON_REG_IMB : 0xbadfbadf
[ 17.440378] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:175 [ERR] FECS_FALCON_REG_DMB : 0xbadfbadf
[ 17.450942] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:181 [ERR] FECS_FALCON_REG_CSW : 0xbadfbadf
[ 17.461304] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:187 [ERR] FECS_FALCON_REG_CTX : 0xbadfbadf
[ 17.471767] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:193 [ERR] FECS_FALCON_REG_EXCI : 0xbadfbadf
[ 17.482573] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:200 [ERR] FECS_FALCON_REG_PC : 0xbadfbadf
[ 17.493038] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
[ 17.503344] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:200 [ERR] FECS_FALCON_REG_PC : 0xbadfbadf
[ 17.513875] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
[ 17.524326] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:200 [ERR] FECS_FALCON_REG_PC : 0xbadfbadf
[ 17.534926] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
[ 17.545338] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:200 [ERR] FECS_FALCON_REG_PC : 0xbadfbadf
[ 17.555678] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
[ 17.566196] nvgpu: 57000000.gpu gk20a_fifo_handle_mmu_fault_locked:1726 [ERR] gr_status_r : 0x400081
[ 17.578107] nvgpu: 57000000.gpu fifo_error_isr:2605 [ERR] channel reset initiated from fifo_error_isr; intr=0x00000100
