I met a issue when running sudo ./apply_binaries.sh in latest JetPack_4.4_DP_JETSON_AGX_XAVIER for jetson agx xavier board.
in JetPack 4.3. This command works fine. But when I installed the the latest JetPack_4.4_DP through sdkmanager 1.1.0.6343. This command report error as below:
~/nvidia_sdk/JetPack_4.4_DP_Linux_DP_JETSON_AGX_XAVIER/Linux_for_Tegra$ sudo ./apply_binaries.sh
dpkg: error processing package nvidia-l4t-init (–install):
installed nvidia-l4t-init package post-installation script subprocess returned error exit status 9
Setting up nvidia-l4t-multimedia-utils (32.4.2-20200408182620) …
Setting up nvidia-l4t-oem-config (32.4.2-20200408182620) …
Setting up nvidia-l4t-tools (32.4.2-20200408182620) …
Setting up nvidia-l4t-wayland (32.4.2-20200408182620) …
Setting up nvidia-l4t-weston (32.4.2-20200408182620) …
dpkg: dependency problems prevent configuration of nvidia-l4t-x11:
nvidia-l4t-x11 depends on nvidia-l4t-init (= 32.4.2-20200408182620); however:
Package nvidia-l4t-init is not configured yet.
I uploaded the full log for this command here.
Please help if you know the reason.
…error_report.log (10.0 KB)
