I’m trying to use my Ubuntu 18.04 VM to flash and setup my AGX Xavier but keep encountering the following error in the SDK Manager.
“Drivers for Jetson: Failed to execute commands with GenericInstaller”
Here’s the contents of the log file NV_L4T_DRIVERS_T194_COMP.log:
"Info: [ Disk Avail:20.09 GB ]
Info: NV_L4T_DRIVERS_T194_COMP include 1 package
Info: change working directory to /home/user/Desktop/shared/JetPack_4.4_Linux_JETSON_AGX_XAVIER
Info: [ Package PreInstall Started ]
Info: current working directory is /home/user/Desktop/shared/JetPack_4.4_Linux_JETSON_AGX_XAVIER
Info: exec_command: sudo rm -rf /home/user/Desktop/shared/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/
Info: [ Package PreInstall Finished Successfully ]
Info: [ Package Install Started ]
Info: exec_command [host]:
#!/bin/bash
set -e
function safe_apt_install {
echo “*begin $1, $2”
tmp_log=/tmp/jetpack_dpkg_log.txt
sudo rm -f $tmp_log
set +e; $1 2>&1 | tee $tmp_log; CMD_STATUS=${PIPESTATUS[0]}; set -e
while [ ${CMD_STATUS} -ne 0 ]; do
if grep -q -e “is locked by another process” -e “E: Could not get lock /var/lib” $tmp_log; then
sudo rm -f $tmp_log
echo “Waiting $2 seconds for apt to be available”; sleep ${2}
else
echo “Unhandled error when running $1”; exit 1
fi
done
sudo apt-get update || true
safe_apt_install “sudo apt-get install -y pigz lbzip2” 5
tar xf /home/user/Desktop/shared/Jetson_Linux_R32.4.3_aarch64.tbz2
Info: exec_command: /tmp/tmp_NV_L4T_DRIVERS_T194_COMP.sh
Hit:1 Index of /ubuntu bionic InRelease
Get:2 Index of /ubuntu bionic-updates InRelease [88.7 kB]
Hit:3 Index of /ubuntu bionic-security InRelease
Get:4 Index of /ubuntu bionic-backports InRelease [74.6 kB]
Fetched 163 kB in 2s (65.7 kB/s)
Reading package lists…
*begin sudo apt-get install -y pigz lbzip2, 5
Building dependency tree…
Reading state information…
lbzip2 is already the newest version (2.5-2).
pigz is already the newest version (2.4-1).
The following packages were automatically installed and are no longer required:
efibootmgr libegl1-mesa libfwup1 libllvm9 libwayland-egl1-mesa
Use ‘sudo apt autoremove’ to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Info: [ Package Install Finished with Error ]
Info: [ 64.00 KB used. Disk Avail: 20.09 GB ]
Info: [ NV_L4T_DRIVERS_T194_COMP Install took 2m18s ]
Error: [error]: : [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_DRIVERS_T194_COMP.sh; [error]: tar: Exiting with failure status due to previous errors
