Problem started when I was trying to convert Keras model with TensorRT.
File “TensorRT.py”, line 113, in
main()
File “TensorRT.py”, line 106, in main
convert(args.p)
File “TensorRT.py”, line 88, in convert
convertFP16(modelPath, fp16Path)
File “TensorRT.py”, line 59, in convertFP16
converter = trt.TrtGraphConverterV2(input_saved_model_dir=modelPath, conversion_params=conversion_params)
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/compiler/tensorrt/trt_convert.py”, line 899, in init
assert context.executing_eagerly()
AssertionError
Ran into issue after fresh install of Jetpack 4.4 on Jetson Nano which contains tensorflow==2.1.0+nv20.4. After looking into tensorflow trt_convert.py source, found the exception was due to tensorflow executing with tf.executing_eagerly() == False. That was a bit confusing since I was not using any TF 1.x compatibility components in conversion program, model, or training.
– To work around, I added tf.compat.v1.enable_eager_execution() as demonstrated below –
import tensorflow as tf
from tensorflow.python.compiler.tensorrt import trt_convert as trt
print(‘Using Tensorflow version: {0}’.format(tf.version.VERSION))
print(tf.executing_eagerly())
This change allowed me to execute trt.TrtGraphConverterV2 on my keras models
I was under the impression that all TF 2.x versions ran with executing_eagerly == TRUE as default. So as a test I ran the commands below in python3 on Jetson Nano with JP 4.4/tensorflow 2.1.0+nv20.4
> > > 2020-05-08 22:22:59.965357: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcudart.so.10.2
> > > 2020-05-08 22:23:07.427738: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libnvinfer.so.7
> > > 2020-05-08 22:23:07.474677: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libnvinfer_plugin.so.7
> > > False
When I do the same thing on JP 4.3 with tensorflow 2.1.0+nv20.3.tf2
Python 3.6.9 (default, Apr 18 2020, 01:56:04)
[GCC 8.4.0] on linux
Type “help”, “copyright”, “credits” or “license” for more information.
> > > 2020-05-08 22:47:32.666516: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
> > > 2020-05-08 22:47:37.064950: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libnvinfer.so.6
> > > 2020-05-08 22:47:37.067243: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libnvinfer_plugin.so.6
> > > True
I’ve been using TF 1.15 on Nano for a long time without much problems and converted to TF 2.0 a few months back. Have had nothing but problems. In JP 4.3 I converted models to run native tf 2.0 and ran into issues with “RuntimeError: Can’t copy Tensor with type string to device” and the only solution was to run in v1 compatibility mode. Now with JP 4.4 it seems there is an issue with executing_eager behaving differently on Nano than on my desktop. The reason I went down this rabbit hole initially was because I needed to improve model inference performance with TensorRT because my TF 2.x native model was running approx 3 times slower than the model I used in TF 1.15
Would like to see TF 2.x stabilized on the platform. Spending way to much time debugging platform problems.
