I tried the 7zip: $ 7z x ~/jetson-nano-4gb-jp441-sd-card-image.zip
7-Zip [64] 16.02 : Copyright (c) 1999-2016 Igor Pavlov : 2016-05-21
p7zip Version 16.02 (locale=en_US.UTF-8,Utf16=on,HugeFiles=on,64 bits,4 CPUs LE)
Scanning the drive for archives:
1 file, 5642977266 bytes (5382 MiB)
Extracting archive: /home/steve/jetson-nano-4gb-jp441-sd-card-image.zip
ERRORS:
Unexpected end of archive
Path = /home/steve/jetson-nano-4gb-jp441-sd-card-image.zip
Type = zip
ERRORS:
Physical Size = 6450819350
ERROR: Data Error : sd-blob-b01.img
Sub items Errors: 1
Archives with Errors: 1
Open Errors: 1
Sub items Errors: 1
But as it produced blob img anyway, I copied it to my Windows and used Etcher. I put it in the Jetson Nano, and it won’t start:
At this point I am sure if not the file itself, then perhaps some data is lost when downloading from server. (But, the strange part is, Jetpack 4.5.0 works for me but not other versions)
Would you have another download mirror or other advice?
Hi @WayneWWW I tried to do that but unfortunately the only ubuntu I have is the Jetson Nano where the Jetpack 4.5.0 was installed. Would there be another way for Windows?
Are you sure the disk space size is enough for doing this work? Please note that it is 6gb zip file and you will get a larger one even after you decompress it out.
@WayneWWW Yeah I am indeed using Chrome and also thought the same.
So, I am trying with Free Download Manager now. Download should finish under 1 hour and I will confirm whether Chrome is the problem so other users can avoid this problem.
