Thank you very much @WayneWWW , Looking forward to your progress !
Seeing lots of different info about using DTB/overlays…
You can’t use jetson-io and/or extlinux FDT to load a DTB or “bad things will probably happen”. Is that currently correct? I do know (from lots of hair pulling this weekend) that if you do specify an FDT in extlinux.conf, uboot will echo a kernel command line with the extlinux.conf APPEND parameters but it will actually load the ones from the QSPI and ignore the ones from APPEND.
Hello there,
can we get the changelog for 32.5.1 and 4.5.1?
Cheers
Thank you!
Kudos to all moderators. Always there to answer questions as quick as they can.
L4T 32.5.1
- Developer preview support for Jetson TX2 NX module.
- Developer preview of pre-built Real-Time Kernel Package for Jetson AGX Xavier. Refer to the “Using the L4T Real-Time Kernel Package” section.
All other features remain the same as L4T 32.5.
