Hi I’m trying to flash a Jetson TX2 with Jetpack 4.6.1 or 4.6.2 with both cases I experience the following failures depicted in SDK Manager’s terminal (this terminal sample is with Jetpack 4.6.1):
08:01:00 INFO: Drivers for Jetson - target_image: [ NV_L4T_DRIVERS_T186_COMP Install took 26s ]
08:01:00 INFO: Drivers for Jetson - target_image: command finished successfully
08:01:00 SUMMARY: Drivers for Jetson - target_image: Install completed successfully.
08:01:00 DEBUG: running command < true >
08:01:00 INFO: command finished successfully
08:01:00 DEBUG: File System and OS - target_image: using adapter to install NV_L4T_FILE_SYSTEM_AND_OS_T186_COMP@JETSON_TX2_TARGETS to /mnt/f438f6fb-2af5-490e-a73a-605fd3cc51ae/nvidia/nvidia_sdk/JetPack_4.6.1_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/rootfs/
08:01:00 INFO: File System and OS - target_image: exec_command: /tmp/tmp_NV_L4T_FILE_SYSTEM_AND_OS_T186_COMP.sh
08:03:42 : File System and OS - target_image: WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
08:03:42 INFO: File System and OS - target_image: Get:1 file:/var/cuda-repo-10-2-local-10.2.89-440.40 InRelease
08:03:42 INFO: File System and OS - target_image: Get:10 file:/var/cuda-repo-cross-aarch64-ubuntu1804-10-2-local Release [563 B]
08:03:42 INFO: File System and OS - target_image: Get:12 file:/var/visionworks-repo Release [1,999 B]
08:03:42 INFO: File System and OS - target_image: Get:14 file:/var/visionworks-tracking-repo Release [2,008 B]
08:03:42 INFO: File System and OS - target_image: Hit:15 Index of /ubuntu xenial InRelease
08:03:42 INFO: File System and OS - target_image: Hit:16 Index of /ubuntu xenial-updates InRelease
08:03:42 INFO: File System and OS - target_image: Hit:17 Index of /ubuntu xenial-backports InRelease
08:03:42 INFO: File System and OS - target_image: Get:20 http://dl.google.com/linux/chrome/deb stable InRelease [1,811 B]
08:03:42 INFO: File System and OS - target_image: Hit:23 Index of /diesch/testing/ubuntu xenial InRelease
08:03:42 INFO: File System and OS - target_image: Hit:27 Index of /graphics-drivers/ppa/ubuntu xenial InRelease
08:03:42 INFO: File System and OS - target_image: Hit:28 Index of /ubuntu xenial-security InRelease
08:03:42 INFO: File System and OS - target_image: Hit:30 Index of /webupd8team/java/ubuntu xenial InRelease
08:03:42 INFO: File System and OS - target_image: The following signatures couldn’t be verified because the public key is not available: NO_PUBKEY 4EB27DB2A3B88B8B
08:03:43 INFO: File System and OS - target_image: Ign:29 https://www.scootersoftware.com bcompare4 InRelease
08:03:44 INFO: File System and OS - target_image: Hit:31 https://www.scootersoftware.com bcompare4 Release
08:03:45 INFO: File System and OS - target_image: Reading package lists…
08:03:45 ERROR: File System and OS - target_image: E: The repository ‘http://dl.google.com/linux/chrome/deb stable InRelease’ is not signed.
08:03:45 INFO: File System and OS - target_image: [ Package Install Finished with Error ]
08:03:45 ERROR: File System and OS - target_image: command terminated with error
08:03:45 SUMMARY: Flash Jetson TX2 - flash: Depends on failed component
What am I doing wrong?
SDKM_logs_JetPack_4.6.2_Linux_for_Jetson_TX2_modules_2022-08-15_09-33-49.zip (113.3 KB)
