Hi
I am using Jetpack 4.6.3
I am trying connect usb camera using V4L2
I can see the camera (/dev/video)
After some time (few minutes) the v4l2 disconnect
I used the same setup (camera and cable) with earlier version of jetpack and there was no disconnections
hello alalieli,
may I know what’s the background running services?
please also setup a terminal for running $ dmesg --follow
, please share the error logs when you see disconnect issue.
