Jetpack 4.6 and Deepstream 5.1 install issues
After updating to jetpack 4.6 i am attempting to install deepstream 5.1 on Xavier NX
getting this error
tsudo apt-get install ./deepstream-5.1_5.1.0-1_arm64.deb
Reading package lists... Done
Building dependency tree
Reading state information... Done
Note, selecting 'deepstream-5.1' instead of './deepstream-5.1_5.1.0-1_arm64.deb'
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 deepstream-5.1 : Depends: libnvinfer7 (>= 7.1.0) but it is not installable
                  Depends: libnvparsers7 (>= 7.1.0) but it is not installable
                  Depends: libnvonnxparsers7 (>= 7.1.0) but it is not installable
                  Depends: libnvinfer-plugin7 (>= 7.1.0) but it is not installable
E: Unable to correct problems, you have held broken packages.
You can edit /etc/apt/sources.list.d/nvidia-l4t-apt-source.list and replace .6 with .5:
deb https://repo.download.nvidia.com/jetson/common r32.5 main
#deb https://repo.download.nvidia.com/jetson/common r32.6 main
deb https://repo.download.nvidia.com/jetson/t194 r32.5 main
#deb https://repo.download.nvidia.com/jetson/t194 r32.6 main
Then type sudo apt update and try again to install DeepStream 5.1.
Made the edit and deepstream installed
The issue now is the python app dosnet seem to have there pybinds
I have reinsalled the pybinds. and still get this
File “deepstream_test_1_usb.py”, line 60, in osd_sink_pad_buffer_probe
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
AttributeError: module ‘pyds’ has no attribute ‘gst_buffer_get_nvds_batch_meta’
this fixed latest error
$pip3 install pyds-ext
Deepstream 5.1 only supports JetPack4.5.1. It can not work with JetPack 4.6.
Was able to get Deepstream 5.1 running with Jetpack 4.6 by following @kirushyk instructions.
Also was able to get Python deepstream apps running by executing
By the why thanks for the 20W 6 Core feature in jetpack 4.6
I needed that.
Any updates? I need jetpack 4.6 and deepstream too.
I used your method and it’s working fine for now.
Wanted to know if there are any limitations, I mean why Deepstream wasn’t installing in the first place?
After making the changes you suggested, should I expect any glitches in its working?
I have been running Yolo3 (not tiny Yolo) on my XavierNX with Deepstream 5.1 with jetpack 4.6 for awhile and I haven’t seen any issues.
