Hello, we’re attempting to flash JetPack 4.6 using the new initrd flashing tool with the goal of booting from an encrypted NVMe drive.
We’ve utilized some of the scripts found in the JetsonHacks “bootFromExternalStorage” GitHub Repo to prepare the host system and download the necessary BSP, rootfs, and Secureboot packages.
install_dependencies.shto install flash script dependencies -
get_jetson_files.shto download BSP and rootfs
Then, referencing Workflow 10 in README_initrd_flash.txt in which the internal and external images are generated separately, and then flashed together…
Workflow 10
Workflow 10: Generate images for internal device and external device seperately
then flash
The flashing tool supports a three-step process: "to generate images for an
internal device, then generate them for an external device, then flash.
This is enabled by using the "append" option. Four examples below show how it
works.
Example 1: Generate a normal root filesystem configuration for the internal device
, then generate an encrypted root filesystem for the external device, then flash
First step: Put the device into recovery mode, then generate a normal root
filesystem for the internal device:
$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --no-flash jetson-xavier internal
Second step: Put the device into recovery mode, then generate an encrypted
filesystem for the external device:
$ sudo ROOTFS_ENC=1 ./tools/kernel_flash/l4t_initrd_flash.sh --no-flash \
--external-device nvme0n1p1 \
-S 8GiB -c ./tools/kernel_flash/flash_l4t_nvme_rootfs_enc.xml \
--external-only --append jetson-xavier external
Third step: Put the device into recovery mode, then flash both images:
$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only
…we came up with a shell script to assist with the process:
custom_flash.sh
UDISKS2_ACTIVE=$(sudo systemctl is-active udisks2.service)
trap cleanup 1 2 3 6
L4T_DIRECTORY="R32.6.1/Linux_for_Tegra"
cleanup()
if [[ ${UDISKS2_ACTIVE} == 'active' ]] ; then
echo "enabling usb mass storage devices"
sudo systemctl start udisks2.service
fi
exit
function flash_jetson
cd $L4T_DIRECTORY
echo "disabling usb mass storage devices"
sudo systemctl stop udisks2.service
read -p "Press enter to generate internal image..."
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --no-flash jetson-agx-xavier-devkit internal
read -p "Press enter to generate external encrypted image..."
--external-only --append jetson-agx-xavier-devkit external
read -p "Press enter to flash both images..."
cleanup
flash_jetson
During the “external” image generation, we noticed an error message that seems relevant to our final issue:
install: cannot stat '/home/<user>/bootFromExternalStorage/R32.6.1/Linux_for_Tegra/rootfs/usr/sbin/nvluks-srv-app': No such file or directory
Between steps, we reboot the device back into recovery mode, as specified in “Workflow 10”.
Finally, after the l4t_initrd_flash.sh script is run, we see the attached display come on and are greeted with the following error message, and an endless boot loop:
My question is, do we need to do something else in order for the NVMe to be able to decrypt upon boot? Or are we missing anything in general? Maybe we’re going about this wrong and it’s more complex than expected. Any insight is greatly appreciated! Thanks!
