I have Jetson Nano P3541 A02 and RPI HQ camera. I installed Jetpack 4.6. I want to activate imx477 by opening the Jetson-io.py file, but I’m new and I don’t know the next steps exactly. Now when I open Jetson-io.py, it quickly appears on the screen and disappears. I think I need to make some adjustments on extlinux.conf. Can you help with this?
hello kullanici746,
is it a production module (i.e. with internal eMMC)?
Jetson-IO does not support with Nano eMMC modules.
I don’t know exactly about eMMC. I think it’s about storage. I don’t think it’s eMMc. It has an SD card slot. I have Jetson Nano 2gb developer kit A02. I installed Jetpack 4.6 image on the SD card and installed it. When I use the command given for jetson-io.py, the Expansion header appears and disappears. I did not fully understand why.I think there is something I missed.Thank you for your interest.
hello kullanici746,
had you try execute jetson-io.py
with root permission?
i.e. $ sudo /opt/nvidia/jetson-io/jetson-io.py
if this still doesn’t works, please try re-flash the board with NVIDIA SDK Manager | NVIDIA Developer.
thanks
