I’m trying to use a SATA based M.2 disk (860 evo) on Xavier NX, freshly installed with Jetpack 5.0.1DP, but the disk is not detected on the system.
But it works normally in Jetpack 4.6.2.
$ lspci -vvnnk
0005:06:00.0 SATA controller [0106]: ASMedia Technology Inc. ASM1062 Serial ATA Controller [1b21:0612] (rev 02) (prog-if 01 [AHCI 1.0])
Subsystem: ASMedia Technology Inc. ASM1062 Serial ATA Controller [1b21:1060]
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 279
Region 0: I/O ports at 103020 [size=8]
Region 1: I/O ports at 103030 [size=4]
Region 2: I/O ports at 103028 [size=8]
Region 3: I/O ports at 103034 [size=4]
Region 4: I/O ports at 103000 [size=32]
Region 5: Memory at 1f40610000 (32-bit, non-prefetchable) [size=512]
Expansion ROM at 1f40600000 [virtual] [disabled] [size=64K]
Capabilities: <access denied>
Kernel driver in use: ahci
Kernel modules: ahci
$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
loop0 7:0 0 16M 1 loop
mmcblk0 179:0 0 29.8G 0 disk
├─mmcblk0p1 179:1 0 12.5G 0 part /
├─mmcblk0p2 179:2 0 268M 0 part /boot/efi
└─mmcblk0p3 179:3 0 17.1G 0 part /var
zram0 251:0 0 857M 0 disk [SWAP]
zram1 251:1 0 857M 0 disk [SWAP]
zram2 251:2 0 857M 0 disk [SWAP]
zram3 251:3 0 857M 0 disk [SWAP]
