Jetpack 5.0.2: UEFI: boot time become longer
The Orin module takes longer boot time when paired with our custom carrier board before serial console print “**WARNING: Test Key is used. **”.
the complete boot log attached here:
boot.log (88.8 KB)
Please enable UEFI debug build and flash your board again. Compare it with devkit case and see which one is getting longer wait in UEFI…
If you ever read your UEFI log by yourself, you will notice you just share a blanked log to us.
Enable UEFI debug build means download the UEFI source code, build the binary again…
Hi, Wayne
I can’t find the uefi source code of linux 35.1 from Jetson Linux 35.1 | NVIDIA Developer, should I build it from git repo according to Build · NVIDIA/edk2-nvidia Wiki · GitHub ?
Yes, please use the github to download source code. UEFI source will be only released on github.
Hi, Wayne
the boot log with uefi debug info attached here:
orin module with custom carrier board: boot_debug.log (198.9 KB)
the same orin module with devkit carrier board: boot_devkit_debug.log (197.5 KB)
Please compare the log by yourself first. Only you are able to dump the timestamp… I cannot tell it because your log file does not provide timestamp…
