- Hi I had some problem about module flash from jetpack 4.6 to 5.0 DP
09:10:36.820 - info: NV_L4T_FLASH_XAVIER_NX_WITH_OS_IMAGE_COMP@JETSON_XAVIER_NX_TARGETS: Parsing module EEPROM:
09:10:36.826 - error: NV_L4T_FLASH_XAVIER_NX_WITH_OS_IMAGE_COMP@JETSON_XAVIER_NX_TARGETS: --- Parsing board ID (ERROR: calculated CRC8 0xc6 != stored CRC8 0xf7) succeeded.
09:10:36.827 - info: Event: NV_L4T_FLASH_XAVIER_NX_WITH_OS_IMAGE_COMP@JETSON_XAVIER_NX_TARGETS - error is: --- Parsing board ID (ERROR: calculated CRC8 0xc6 != stored CRC8 0xf7) succeeded.
09:10:36.829 - error: NV_L4T_FLASH_XAVIER_NX_WITH_OS_IMAGE_COMP@JETSON_XAVIER_NX_TARGETS: --- Parsing board version (ERROR: calculated CRC8 0xc6 != stored CRC8 0xf7) succeeded.
09:10:36.829 - info: Event: NV_L4T_FLASH_XAVIER_NX_WITH_OS_IMAGE_COMP@JETSON_XAVIER_NX_TARGETS - error is: --- Parsing board version (ERROR: calculated CRC8 0xc6 != stored CRC8 0xf7) succeeded.
09:10:36.829 - error: NV_L4T_FLASH_XAVIER_NX_WITH_OS_IMAGE_COMP@JETSON_XAVIER_NX_TARGETS: --- Parsing board SKU (ERROR: calculated CRC8 0xc6 != stored CRC8 0xf7) succeeded.
09:10:36.829 - info: Event: NV_L4T_FLASH_XAVIER_NX_WITH_OS_IMAGE_COMP@JETSON_XAVIER_NX_TARGETS - error is: --- Parsing board SKU (ERROR: calculated CRC8 0xc6 != stored CRC8 0xf7) succeeded.
09:10:36.829 - error: NV_L4T_FLASH_XAVIER_NX_WITH_OS_IMAGE_COMP@JETSON_XAVIER_NX_TARGETS: --- Parsing board REV (ERROR: calculated CRC8 0xc6 != stored CRC8 0xf7) succeeded.
09:10:36.829 - info: Event: NV_L4T_FLASH_XAVIER_NX_WITH_OS_IMAGE_COMP@JETSON_XAVIER_NX_TARGETS - error is: --- Parsing board REV (ERROR: calculated CRC8 0xc6 != stored CRC8 0xf7) succeeded.
09:10:36.829 - error: NV_L4T_FLASH_XAVIER_NX_WITH_OS_IMAGE_COMP@JETSON_XAVIER_NX_TARGETS: Error: Target board not found.
09:10:36.829 - info: Event: NV_L4T_FLASH_XAVIER_NX_WITH_OS_IMAGE_COMP@JETSON_XAVIER_NX_TARGETS - error is: Error: Target board not found.
09:10:36.829 - info: NV_L4T_FLASH_XAVIER_NX_WITH_OS_IMAGE_COMP@JETSON_XAVIER_NX_TARGETS: [ Component Install Finished with Error ]
09:10:36.829 - info: NV_L4T_FLASH_XAVIER_NX_WITH_OS_IMAGE_COMP@JETSON_XAVIER_NX_TARGETS: [host] [ 20.00 KB used. Disk Avail: 61.63 GB ]
09:10:36.829 - info: NV_L4T_FLASH_XAVIER_NX_WITH_OS_IMAGE_COMP@JETSON_XAVIER_NX_TARGETS: [ NV_L4T_FLASH_XAVIER_NX_WITH_OS_IMAGE_COMP Install took 6s ]
09:10:36.830 - error: command error code: 11
- I tried to check my Jetson xavier nx module eeprom to use i2c dump
javier@javier-desktop:~$ sudo i2cdump -f -y 0 0x50
No size specified (using byte-data access)
0 1 2 3 4 5 6 7 8 9 a b c d e f 0123456789abcdef
00: 01 02 03 04 05 06 07 08 03 45 00 00 00 00 00 00 ?????????E......
10: 00 00 00 00 36 39 39 2d 31 33 36 36 38 2d 30 30 ....699-13668-00
20: 30 31 2d 33 30 31 20 45 2e 30 00 00 00 00 00 00 01-301 E.0......
30: 00 00 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
40: ff ff ff ff de fa 3a 2d b0 48 31 35 36 34 34 32 ....??:-?H156442
50: 31 30 31 30 39 33 32 00 00 00 00 00 00 00 00 00 1010932.........
60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
90: 00 00 00 00 00 00 4e 56 43 42 1c 00 4d 31 00 00 ......NVCB?.M1..
a0: ff ff ff ff ff ff ff ff ff ff ff ff de fa 3a 2d ............??:-
b0: b0 48 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ?H..............
c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 f7 ...............?
How to solve this problems?
