Trying to run the bluez-5.53 examples sources - example-advertisement script. Below is the terminal log:
python3 example-advertisement
Advertising forever…
GetAll
returning props
Failed to register advertisement: org.bluez.Error.Failed: Failed to parse advertisement.
File “example-advertisement”, line 227, in
main(args.timeout)
File “example-advertisement”, line 215, in main
ad_manager.UnregisterAdvertisement(test_advertisement)
File “/usr/lib/python3/dist-packages/dbus/proxies.py”, line 141, in call
return self._connection.call_blocking(self._named_service,
File “/usr/lib/python3/dist-packages/dbus/connection.py”, line 652, in call_blocking
reply_message = self.send_message_with_reply_and_block(
dbus.exceptions.DBusException: org.bluez.Error.DoesNotExist: Does Not Exist
In my case, I’m sending a legal, internal request within the system to start advertising the BLE server’s existence so that BLE clients can begin pairing.
I made made many trials and code modifications, after which I was able to run my code using BLE HRM design. Unfortunately after frequently following Ubuntu 20.04 OS upgrades, the recent made few days ago, I was not able to get the system peripheral advertising and client connection anymore. After re-flashing the Orin once again using JP 5.1.2. I could not duplicate the issue as reported here, so I will closed it now and will open another issue with peripheral advertisement.
At this time I’m facing instability with regard to the ble client app running on iPhone iOS 17.1.2 to connect to the server. I was able to reproduce the kernel panic issue reported in the below issue and further analized and fix-tested as reported in the following 2nd link. I’m wondering:
a) when the fix will be officially released.
b) Can I get instruction to compile the OS with the fix and how to re-flash AGX Orin for test and verification.
