Jetpack 5.1.2 - target components keep failing while flashing
Using SDK manager on Ubuntu 20.04 - Host components were installed fine but the target components after downloading completes successfully - fails to flash to Orin nano dev kit.
SDK manager was able to identify the dev kit in step 1. While target component flashing all target components error out wit below messages -
15:06:16 ERROR: File System and OS - target_image: tar: usr/share/ubuntu-wayland/applications: Directory renamed before its status could be extracted
15:06:16 ERROR: File System and OS - target_image: tar: usr/share/ubuntu-wayland: Directory renamed before its status could be extracted
15:06:16 ERROR: File System and OS - target_image: tar: usr/share/aisleriot/cards: Directory renamed before its status could be extracted
15:06:16 ERROR: File System and OS - target_image: tar: usr/share/aisleriot/pixmaps: Directory renamed before its status could be extracted
15:06:16 ERROR: File System and OS - target_image: tar: usr/share/aisleriot: Directory renamed before its status could be extracted
15:06:16 ERROR: File System and OS - target_image: tar: usr/share/fonts/cmap: Directory renamed before its status could be extracted
15:06:16 ERROR: File System and OS - target_image: tar: usr/share/fonts/cMap: Directory renamed before its status could be extracted
15:06:16 ERROR: File System and OS - target_image: tar: usr/share/fonts: Directory renamed before its status could be extracted
15:06:16 ERROR: File System and OS - target_image: tar: usr/share/plymouth/themes: Directory renamed before its status could be extracted
15:06:16 ERROR: File System and OS - target_image: tar: usr/share/plymouth: Directory renamed before its status could be extracted
15:06:16 ERROR: File System and OS - target_image: tar: usr/share/doc/mutter: Directory renamed before its status could be extracted
15:06:16 ERROR: File System and OS - target_image: tar: usr/share/doc/libopencv4.2-java: Directory renamed before its status could be extracted
15:06:16 ERROR: File System and OS - target_image: tar: usr/share/doc/libavahi-common3: Directory renamed before its status could be extracted
15:06:16 ERROR: File System and OS - target_image: tar: usr/share/doc/libatk-adaptor: Directory renamed before its status could be extracted
Are you using a virtual machine or docker to flash the device?
None of them. I am using a Windows machine with Ubuntu on bootable HDD
I’m closing this topic due to there is no update from you for a period, assuming this issue was resolved.
If still need the support, please open a new topic. Thanks
So is Ubuntu running natively?
Can you please try another host PC? As it looks like some disk permission issues.
Also, please always put the full log here; don’t crop it yourself.
