Jetpack 5.1.3 SD image boot error
To update to Jetpack 6, I first created an SD image with Jetpack 5.1.3 and booted it, but after the boot screen, it transitions to a black screen and remains there. From other cases I’ve seen, it should boot properly with 5.1.3, right? Could you let me know what the issue might be? I’ve attached the logs.
I would greatly appreciate it if you could provide any suggestions that might help with this issue.
jetpack_5.1.3_log.txt (78.7 KB)
This log is already in recovery boot. Thus, this log has no point to review.
Please recover from recovery boot with below link first and dump the log again afterwards.
BTW, each line in your log got truncated. Better resizing the terminal when you dump it.
Thank you for the precise solution. It really helped relieve my stress.
