Jetpack 5.1 install on Xavier NX development, BSP Version Mismatch
I Installed an NVME drive on my Xavier and used the SDK Manager to Install the jetpack 5.1. It vailed to to install the multi media component. Error code:
Your device BSP image version is incompatible with the software version you are trying to install. Please flash your device with the right BSP version and try to re-install.
the BPS version is:
head -1 /etc/nv_tegra_release
R35 (release), REVISION: 2.1, GCID: 32413640, BOARD: t186ref, EABI: aarch64, DATE: Tue Jan 24 23:38:33 UTC 2023.
This behavior occurs on both the NVME drive and a MMC. In both cases used on media connected.
Attached the log.
tso_230126_xavier_install-jetpack_5.1.txt (12.0 KB)
Hi jacob.kamminga,
Are you using the devkit or custom board?
What ubuntu version on your host PC? Ubuntu-18.04 or Ubuntu-20.04?
Please provide sdk logs and tar from below path:
/home/<username>/.nvsdkm
Please try to boot up your board with eMMC only. (w/o NVMe connected)
If you want to install SDK components, you should boot up the board and enter desktop first.
Hi Kevin,
I’m using the Devkit.
On the host computer I’m using Ubuntu 20.04
I do not have eMMC I have a MMC slot. The issue happens both on the Mmc and the name. Both used alone without the other connected.
I installed to whole shebang from the sdk OS etc. following the steps in the guide, i.e. losing in after the first step of the OS and then installed the other components the multi media components fails to install during that step.
Attached the .nvsdkm tar gzip.
Jacob
jacob.nvsdkm.tar.gz (401.4 KB)
Sorry name = NVME
%$&$ spelling checker
Is this still an issue to support? Any result can be shared? Thanks
