Jetpack 5.1 kernel panic on reboot
We had this issue in 5.0.2 already.
Is there a fix for this kernel panic already for the 5.1?
 reboot
[  164.497466] Trying to unregister non-registered hwtime source
[  164.499435] Unable to handle kernel NULL pointer dereference at virtual address 0000000000000000
[  164.499707] Mem abort info:
[  164.499809]   ESR = 0x86000004
[  164.499881]   EC = 0x21: IABT (current EL), IL = 32 bits
[  164.500009]   SET = 0, FnV = 0
[  164.500158]   EA = 0, S1PTW = 0
[  164.500233] user pgtable: 4k pages, 48-bit VAs, pgdp=0000000116b4f000
[  164.500367] [0000000000000000] pgd=0000000000000000, p4d=0000000000000000
[  164.500537] Internal error: Oops: 86000004 [#1] PREEMPT SMP
[  164.500654] Modules linked in: lzo_rle lzo_compress realtek zram aes_ce_blk crypto_simd cryptd aes_ce_cipher ghash_ce sha2_ce sha256_arm64 sha1_ce leds_gpio max77620_thermal tegra_bpmp_thermal input_leds userspace_alert tegra210_adma spi_tegra114 overlay binfmt_misc ina3221 pwm_fan nvgpu nvmap
[  164.501357] CPU: 3 PID: 153 Comm: kworker/u12:3 Tainted: G           OE     5.10.104-tegra #1
[  164.501532] Hardware name: Unknown NVIDIA Jetson Xavier NX Developer Kit/NVIDIA Jetson Xavier NX Developer Kit, BIOS 2.1-32413640 01/24/2023
[  164.504602] Workqueue: events_power_efficient phy_state_machine
[  164.510635] pstate: 60c00009 (nZCv daif +PAN +UAO -TCO BTYPE=--)
[  164.516580] pc : 0x0
[  164.518942] lr : phy_link_change+0x40/0x70
[  164.523139] sp : ffff80001155bd20
[  164.526380] x29: ffff80001155bd20 x28: ffffc3073cfa6000
[  164.531893] x27: ffff8000108fbca8 x26: ffff495f9715c648
[  164.537145] x25: 0000000000000000 x24: ffff495e451f0000
[  164.542658] x23: ffff495e5b4b3cf8 x22: ffff495e44c16580
[  164.548428] x21: 0000000000000000 x20: ffff495e451f0000
[  164.553851] x19: ffff495e5b4b3800 x18: 0000000000000000
[  164.559295] x17: 0000000000000007 x16: 000000000000000e
[  164.564532] x15: 0000000000000004 x14: 0000000000000019
[  164.570303] x13: 0000000000000000 x12: ffff495e57e5c8c8
[  164.575399] x11: ffff495e57e5c6d8 x10: 0000000000000a80
[  164.580807] x9 : ffff495e44670d7c x8 : fefefefefefefeff
[  164.586402] x7 : 0000000000000018 x6 : ffff495e44670d6c
[  164.591570] x5 : 0000746e65696369 x4 : 000000000000002f
[  164.597253] x3 : 0000000000000000 x2 : ffffc3073b6de450
[  164.602590] x1 : 0000000000000000 x0 : ffff495e451f0000
[  164.607670] Call trace:
[  164.610380]  0x0
[  164.611961]  phy_state_machine+0x184/0x220
[  164.616244]  process_one_work+0x1c4/0x4a0
[  164.620268]  worker_thread+0x54/0x430
[  164.623942]  kthread+0x148/0x170
[  164.626939]  ret_from_fork+0x10/0x24
[  164.630694] Code: bad PC value
[  164.633578] ---[ end trace dc750f5d02f3052d ]---
[  164.638378] Kernel panic - not syncing: Oops: Fatal exception
[  164.643721] SMP: stopping secondary CPUs
[  164.647750] Kernel Offset: 0x43072b520000 from 0xffff800010000000
[  164.653864] PHYS_OFFSET: 0xffffb6a2c0000000
[  164.657635] CPU features: 0x8240002,03802a30
[  164.662177] Memory Limit: none
[  164.665077] ---[ end Kernel panic - not syncing: Oops: Fatal exception ]---
I can’t comment whether it’s fixed or not as there qre couple issues fixed in new release.
Please get it a try with JetPack 5.1.
Oh I mean the text is from 5.1
Wayne had a patch for the kernel in 5.0.2
Do you have one for 5.1 already or do we have to deal with kernel panics on reboot again?
Where does this come from? From the ethernet? or something you are not sure either?
Hey @WayneWWW I am not sure, but as you pointed out the phy_link_change would point to ethernet, yep.
Oh. If it is that issue which happened intermittently, then it is not resolved yet. Sorry about it.
The workaround patch from 5.0.2 is still needed.
Seems I’ve missed that. I’ve only got one applied for the panic caused by the display port. Can you link me the patch for the ethernet panic?
Please try to remove below in your kernel-dts/t19x-common-platforms/tegra194-platforms-eqos.dtsi
  interrupt-parent = <&tegra_main_gpio>;
  interrupts = <TEGRA194_MAIN_GPIO(G, 4) IRQ_TYPE_LEVEL_LOW>;
The side effect is wake on LAN will not work after it.
