Hi there,
I have installed Jetpack 5.1 on Xavier NX.
I am using a standard power supply that outputs 12V , 5A
I have selected the 20W 6 core mode.
When running our application i get this annoying popups which moves my power mode to 10W 2 cores.
I know all about the IANA power limiter for warning and critical , and i know that on jetpack 5.1 you have no way to mess with them since it is inside the kernel and not exposed to a change.
I can not understand why the throttle happens on a TX2 with the same application we have no problems and throttling so how come that on Xavier NX we get them ?
Any advice would be appreciated
Sorry for the late response, have you managed to get issue resolved or still need the support?
Could you try with JP5.1.2?
I’m closing this topic due to there is no update from you for a period, assuming this issue was resolved.
If still need the support, please open a new topic. Thanks
Hi omer.levy,
Are you using the devkit or custom board for Xavier NX?
Could you share result of the following command on your board?
grep "" /sys/class/hwmon/hwmon*/oc*
