I need some help installing JP5 on my Xavier NX devkit using the SD card image? Under SD card image method it says:
“Jetson Xavier NX Developer Kit must be flashed at least once with SDK Manager or flash.sh command line tool before the JetPack 5.0 DP SD Card image can be used. For instructions on how to use the SD Card image, see Getting Started with Jetson Xavier NX Developer Kit.”
Where can I find instructions on using the flash.sh command line tool?
