JetPack 6.0 Flash Issues:
Hello NVIDIA Community.
I am a student from Japan, so I apologize if there are any unnatural phrases in my English.
I am trying to flash JetPack 6.0(rev2) onto a Jetson Orin Nano Developer Kit, but I am encountering several issues during the installation process with SDK Manager. Below is a summary of the problems I am facing.
Currently, JetPack 5.1.3 is booting from an SD card without any issues, and I am attempting to install JetPack 6.0 (rev2) onto an NVMe SSD (formatted with ext4). My host machine is an HP Ryzen laptop running Ubuntu 22.04, and I am not using a virtual machine. Additionally, the OEM Configuration is set to Runtime mode. The error occurs when the flash status reaches 94%.
The following issues were generated from the logs using ChatGPT:
Screenshots.zip (2.4 MB)
SDKM_logs_JetPack_6.0_(rev._2)_Linux_for_Jetson_Orin_Nano_modules_2024-09-12_16-31-17.zip (237.4 KB)
  1. Java SSL Certificate Error:
• Error: cannot open ‘/etc/ssl/certs/java/cacerts’ for reading
• During installation, there is an issue accessing Java SSL certificates. I have verified that the certificates are up to date, but this error persists.
  1. RCM State Errors During Flash:
• Errors: rcm_state open failed and ERROR: failed to read rcm_state
• These errors occur when trying to flash the device in recovery mode. It seems like there is an issue with communication between the host PC and the device.
  1. Block Errors During Flash:
• Errors: 53899 blocks, 77459 blocks, and 129883 blocks
• These block-related errors occur during the flash process, leading to failed installation attempts.
  1. NFS Mount or Flash Command Failure:
• Error: Either the device cannot mount the NFS server on the host or a flash command has failed
• I have not configured an NFS server, but this error keeps appearing. Could this be due to a misconfiguration or a default setting?
  1. L4TConfiguration.dts Warnings:
• Warning: Node /fragment@0 has a unit name, but no reg property
• These warnings appear multiple times during the flash process. I am unsure if this is a critical issue or something that can be ignored. Could it be related to the other errors?
  1. CUDA-related Dependency Errors:
• During the installation of CUDA packages, dependency errors are reported, possibly due to version mismatches or missing packages.
  1. Nsight Systems and Nsight Graphics Errors:
• Errors during the installation of Nsight Systems and Nsight Graphics indicate dependency issues, particularly related to missing or conflicting libraries.
  1. VPI (Vision Programming Interface) Dependency Issues:
• Errors have also been encountered during the installation of VPI, which seem to be related to dependency or version compatibility problems.
I have already tried the following commands to resolve the dependency issues, but they did not resolve the problem:
• sudo apt-get update
• sudo apt-get upgrade
• sudo apt-get install -f
I would greatly appreciate any guidance, especially regarding the RCM state, block errors, and dependency-related issues.
Additionally, if there is anything else in the logs that could provide more information, I would appreciate your insights.
Thank you for your assistance.
Can you try to install/upgrade Jetpack 6 on your SD card first. Then you can use SDK Manage to flash NVMe SSD. Make sure to turn off firewall on your host machine before flashing NVMe SSD.
If you still have the issue, the issue maybe your Jetson UEFI Firmware version. You can check this link to upgrade your firmware
