Hello folks,
We are conducting a reboot test on the JetPack 6.0 production release with our customized carrier. The same hardware platform was verified with JetPack 5.1.1 without issues.
However, with the JetPack 6.0 production release, we are experiencing a 1/2000 failure rate in our reboot tests. The final line of the reboot failure halts at…
[ 9.549867] WARNING: CPU: 6 PID: 1284 at kernel/workqueue.c:1668 __queue_delayed_work+0xe8/0x110
[ 9.549883] WARNING: CPU: 3 PID: 160 at kernel/workqueue.c:3087 __flush_work.isra.0+0x2e8/0x320
[ 9.550275] ---[ end trace 4e84ab22e45cb48c ]---
[ 9.550290] ---[ end trace 4e84ab22e45cb48d ]---
[ 10.555215] WARNING: CPU: 6 PID: 1284 at kernel/workqueue.c:1670 __queue_delayed_work+0xc4/0x110
[ 10.555406] ---[ end trace 4e84ab22e45cb48e ]---
[ 10.655925] kernel BUG at kernel/time/timer.c:967!
Do you possibly have any feedback to help us fix this issue?
The logs for a failed boot and a successful boot can be found below.
boot_failed.log (63.7 KB)
boot_good.log (66.7 KB)
Thank you very much!
