JetPack 6.0 with kernel 6.7.8 - no display output after UEFI
Dear NVidia Team
We are testing JetPack 6.0 with the official kernel 6.7.8 and the AGX Orin Module.
Now when we boot the system, we first see the UEFI Menu on our Monitor, but after the screen goes black. Login over ssh is possible.
Here you can find the file /var/log/Xorg.0.log and the dmesg output:
Xorg.0.log (7.3 KB)
dmesg.log (63.5 KB)
Connected is a DP Monitor and we are using a custom board which works with JetPacks 5.1.x.
Thank you for your help.
Kind regards
Dear NVidia Team
We checked with the kernel 5.15 and it works, so it has to do with the new kernel version.
Thank you.
Hi Nvidia Team
Any update on this issue? If you need further information from us, let me know.
Thank you.
Dear NVidia
Could you please help us with this topic?
We tested also with the linux kernel 6.8.1 and see also that after the UEFI, the Display Port is not working anymore. The system boots up and we can connect to it over ssh.
Thank you.
It seems like the following messages are causing the issue:
host1x drm: iommu configuration for device failed with -ENOENT
drm drm: [drm] No compatible format found
drm drm: [drm] Cannot find any crtc or sizes
We would really appreciate if NVidia could confirm the issue and let us know if there is a solution for this.
Can you try disabling the display hand-off from UEFI to the kernel in the UEFI menu?
To do this enter the UEFI menu and set “SOC Display Hand-Off Mode” to “Never” …
Device Manager -->
     NVIDIA Configuration -->
         Boot Configuration -->
            SOC Display Hand-Off Mode --> 'Never'
Hi Jonathanh
We changed the setting but still face the same behavior.
Thank you.
I had the problem that display is not working on 6.6. I think that drivers need updated because I had missmatch:
Hi jonathanh
Do you have any update on this topic for us? The uefi setting did not solve it.
Thank you.
I’m waiting for jetpack 6 GA and try again. In theory is out today 17th April
Also I don’t why jetson agx orin is still on 540, and not with 550.67 as kernel open module
Hi Nvidia Team
Can anyone confirm this issue and also confirm that JP6.0 GA will solve it?
Otherwise we still need support for this case.
Thank you.
