I’m running SDK Manager 2.2.0.12021 x86_64 on Ubuntu 22.04.5 and upgrading Jetson Orin AGX Developer Kit to JetPack 6.1 through USB-C port. The Linux image was flashed successfully and it boots fine. I configured the Ethernet network manually to set a fixed IP address to 192.168.0.42, DNS to 205.171.3.25, the same as other PCs on my local network. Jetson is accessible on my LAN, but it can’t access Internet:
ping: yahoo.com: Temporary failure in name resolution
This produces Internet connection failure
message in SDK Manager. What is the solution?
BTW, I had the same problem with default automatic settings in IPv4 tab.
After some wasted time and no discernible changes in Ubuntu configuration on the Jetson, Internet connection works. I would much prefer a repeatable procedure than some obscure magic.
Unfortunately, installation can not proceed, due to bad script run remotely by SDK Manager:
Internet connection check failure.
command < ssh -F /dev/null -o PreferredAuthentications=password -o PubkeyAuthentication=no -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no -o ConnectTimeout=5 nick@192.168.0.42 'ping -c 3 nvidia.com || wget --spider -T 5 -t 1 www.nvidia.com' > terminated with error, exitCode: 255.
I tried this on my desktop:
paul@desktop:~$ ping -c 3 www.nvidia.com
PING e33907.a.akamaiedge.net (23.46.228.170) 56(84) bytes of data.
64 bytes from a23-46-228-170.deploy.static.akamaitechnologies.com (23.46.228.170): icmp_seq=1 ttl=56 time=32.8 ms
64 bytes from a23-46-228-170.deploy.static.akamaitechnologies.com (23.46.228.170): icmp_seq=2 ttl=56 time=33.0 ms
64 bytes from a23-46-228-170.deploy.static.akamaitechnologies.com (23.46.228.170): icmp_seq=3 ttl=56 time=32.6 ms
--- e33907.a.akamaiedge.net ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2002ms
rtt min/avg/max/mdev = 32.644/32.806/32.976/0.135 ms
paul@desktop:~$ ping -c 3 nvidia.com
PING nvidia.com (34.194.97.138) 56(84) bytes of data.
--- nvidia.com ping statistics ---
3 packets transmitted, 0 received, 100% packet loss, time 2029ms
It seems that using nvidia.com
in the script instead of www.nvidia.com
is the source of this problem. This issue was already raised in Anyone able to ping nvidia.com? and SDK Manager fails, can't ping nvidia.com posts. Perhaps it’s time to make a correction in Internet connection test script.
I chose “Ignore” button and installation failed. Now Jetson doesn’t see Internet again. Pretty horrible experience. Should I try JetPack 6.0 instead? Is it more solid?
Reboot doesn’t help, but this sequence does:
sudo dhclient -r
sudo dhclient
What is the problem?
