Hi NVIDIA Team,
We encountered a display corruption issue on Jetson Orin NX running JetPack 6.2.1
When performing a software reboot using:
sudo reboot
the display becomes corrupted and shows full-screen random colored noise/artifacts during the reboot process.
The issue occurs during the transition from the running Linux system to the next boot.
serial_log.txt (3.3 KB)
log.zip (270.4 KB)
wichiu
September 29, 2026, 6:57am
5
The logs show an RT kernel and an LCFC/VC50L platform identifier. Could you please clarify:
Are you using an LCFC VC50L carrier board? Is the BSP vendor-provided or customized by you?
Is the monitor connected directly through HDMI/DP, or through an adapter?
Does the display return to normal after reboot, or does the corruption persist?
1,Yes,I am using an LCFC VC50L carrier board.The BSP is vendor-provided.
2,Yes,the monitor is connected directly through HDMI/DP
3, The display returns to normal after the reboot completes. The corruption only occurs during the software reboot process.
wichiu
October 14, 2026, 6:55am
7
I will check whether your issue can be reproduced on our devkit.
I will update here once I have an outcome.
wichiu
October 15, 2026, 2:41am
8
I could reproduce this issue using the RT kernel on our Devkit.
There’s one thing I need you to confirm:
Did the random color noise/artifacts across the entire screen only last for a few seconds, then resume the normal boot process ?
wichiu:
Yes, the artifacts only last for a few seconds, and the system then continues booting normally. This issue does not affect the reboot process, but it impacts the user experience, so we would like to resolve it.
wichiu
October 15, 2026, 9:56am
10
Can you try this solution first?
It happens also in my Jetson Orin AGX Developer Kit with PREEMPT_RT kernel and Jetpack 6.2, both rebooting and shutting down.
It’s not always white noise, it sometimes shows black areas and green lines, last time I saw something like this was on a desktop and the GPU was fried.
Is this something we should worry about?
wichiu
October 21, 2026, 7:36am
11
The issue is resolved in JP7.2.1.
So, suggest updating to JP 7.2.1.
