In jetpack 6.2.1, We are opening three cameras with libArgus, when close them and reopen, meet a crash issue and system dump.
There is the dmesg log, We didn’t meet the issue while using Jetpack 5.1.4, it happened after upgrade to Jetpack 6.2.1.
ArgusCamera_reopen_crash_20260630.log (18.5 KB)
I had search for some topics, it seems that jetpack 5.1.3 had solved the issue like, does it reopen in jetpack 6.2.1?
Apply the patch from below link to verify.
[Argus] Long run stability issue.
https://forums.developer.nvidia.com/t/318999/5
(Fixed in Jetpack 6.2.2 r36.5)
I replaced there two so lib, and do a test again, when reopen for almost 20 times, It happens again.
Apply these libs to try .
Get the daemon log by journalctl -u nvargus-daemon -f if still failed.
libnvscf.so.36.5.checkdone (8.6 MB)
libnvfusacap.so.r36.5.ig-err-timeout (232.0 KB)
