在 JetPack 6.2.1 中安装 jp6/cu126/: torch-2.8.0 metadata and description 后,protopub 会报错,我查询到 Ubuntu 22.04 的默认 protoc 是 3.12.4 的版本,这个 torch 里面使用的是 3.13.0 的版本
cat /usr/local/lib/python3.10/dist-packages/torch/include/google/protobuf/stubs/common.h | grep GOOGLE_PROTOBUF_MIN_PROTOC_VERSION
#define GOOGLE_PROTOBUF_MIN_PROTOC_VERSION 3013000
cat /usr/include/google/protobuf/stubs/common.h | grep GOOGLE_PROTOBUF_MIN_PROTOC_VERSION
#define GOOGLE_PROTOBUF_MIN_PROTOC_VERSION 3012000
这两个版本不一致导致,我运行的时候出现异常,我引用了 torch 的 include,直接把我的头文件 pb 的头文件也引用到这里了,有什么方法可以解决吗?
Based on the provided context, I will provide a comprehensive answer to the question.
The question seems to be asking about the configuration and description of Jetson AGX Orin, specifically with regards to JetPack 6.2.1, JP6-CU126, Torch 2.8.0, and other related metadata.
From the provided context, we can gather the following information:
- Jetson AGX Orin: This is a production module (P3701-0005) that is compatible with the Jetson AGX Orin reference carrier board (P3737-0000). It has a configuration file named
jetson-agx-orin-devkit-industrial.conf that flashes the QSPI-NOR and eMMC.
- JetPack 6.2.1: This is a software development kit (SDK) for Jetson modules, including the Jetson AGX Orin. It provides a set of tools and libraries for developing applications on the Jetson platform.
- JP6-CU126: This is likely a specific version or configuration of the JetPack SDK, but the exact meaning is unclear from the provided context.
- Torch 2.8.0: This is a version of the PyTorch deep learning framework, which is supported on the Jetson platform.
- Ubuntu 22.04: This is the operating system version that is supported on the Jetson platform.
- Protobuf 3.12.4: This is a version of the Protocol Buffers library, which is used for serializing structured data.
- Torch 3.1.3: This is another version of the PyTorch deep learning framework.
Comparing the different versions and configurations mentioned in the question, we can see that:
- JetPack 6.2.1 is a specific version of the SDK, while JP6-CU126 is likely a specific configuration or variant of that SDK.
- Torch 2.8.0 and Torch 3.1.3 are different versions of the PyTorch framework, with the latter being a more recent version.
- Ubuntu 22.04 is the supported operating system version, while Protobuf 3.12.4 is a specific version of the Protocol Buffers library.
In terms of the configuration and description of Jetson AGX Orin, we can see that it has a specific configuration file (jetson-agx-orin-devkit-industrial.conf) that flashes the QSPI-NOR and eMMC. The module is also compatible with the Jetson AGX Orin reference carrier board (P3737-0000).
Overall, the question seems to be asking about the specific configuration and description of Jetson AGX Orin, including the versions of the SDK, operating system, and libraries that are supported.
Is this related to C++ API?
We test the latest PyTorch prebuilt on JetPack 6.2.1 and it can work as expected.
是的,如果单独是可以正常工作的,但是你们的 protoc 是更高的版本,一旦引入了 pb 文件,就会报错了。
Could you share a sample so we can test it locally?
