JetPack 6.2 - Intermittent NVMe PCIe probe failure on reboot (Orin NX, boot fails)
After updating to JetPack 6.2, my Jetson Orin NX occasionally fails to boot on reboot.
The NVMe SSD drops off the PCIe bus during probe, so the root filesystem can’t be mounted and the system falls to the recovery shell.
Console errors:
nvme nvme0: Removing after probe failure status: -19
pcieport 0004:00:00.0: AER: Uncorrected (Fatal) error received
PCIe Bus Error: severity=Uncorrected, type=Transaction Layer, (Requester ID), device [10de:229c]
pcieport 0004:00:00.0: AER: device recovery failed
pci 0004:01:00.0: AER: can’t recover (no error_detected callback)
Data Link Layer Link Active not set in 1000 msec
AER: Root Port link has been reset / subordinate device reset failed
Because the NVMe is removed, the root partition is not found:
mount: /mnt: can’t find PARTUUID=71d8b760-717d-42d8-82dc-832a284dc6d3
ERROR: mounting PARTUUID=… as /mnt fail
ttyTCU0: Press [ENTER] to start bash in 30 seconds…
This is intermittent - sometimes the board boots normally, sometimes it fails
with the above. It started after the JetPack 6.2 update.
Environment:
  • Module: Jetson Orin NX
  • JetPack: 6.2
  • Boot device: NVMe SSD (PCIe)
Questions:
  1. Is this a known PCIe/NVMe link-stability issue on JetPack 6.2 for Orin NX?
  2. Is there a recommended fix - e.g. disabling PCIe ASPM (pcie_aspm=off kernel
    parameter), or an ASPM/L1 power-management / device-tree setting - to
    stabilize the NVMe link?
  3. Could this instead be a hardware issue (re-seating the M.2 / thermal)?
Hi @gumin.kwon
Is this a new Orin NX device? Could you help me dump the full uart log in your boot failure?
I mean since the power on situation but not just the last few lines.
This is not a standalone Orin NX devkit - it’s the onboard Jetson Orin NX
inside a Unitree G1 robot. So it’s not a brand-new module; it was working fine
before, and the problem started after the JetPack 6.2 update.
Because it’s embedded in the robot, accessing the debug UART / serial console
is difficult - I can’t easily connect a serial cable to capture the full
power-on log.
Is there an alternative way to collect the boot log? For example, can I retrieve
it from a previous boot via /var/log (when it does boot successfully), or is
there a way to capture the UART without opening the robot?
Hi @gumin.kwon
Unfortunately, I need the MB1 log which would only appear in the UART log.
How long has this module been in use? Jetpack6.2 has been released for like 2 years ago. Why this issue coming out today? Do you update the BSP version recently?
This module has been in use for about 5 months. It was on JetPack 5.x before, and I installed JetPack 6.2 last Thursday. The problem started after that.
I’m not entirely sure what counts as a BSP or system update, so let me explain what I did. To run GEAR-SONIC (a model from NVIDIA), I had to upgrade JetPack to this version. At the same time as the JetPack upgrade, I also updated the firmware, using the package provided by Unitree.
I did the same setup on a different robot before and did not have this problem.
About the MB1 / UART log: this Orin NX is the onboard compute inside a Unitree G1 robot, not a standalone devkit, so accessing the debug UART is difficult. I will check whether the G1 exposes a debug serial port, and I may also need to ask Unitree about it.
Hi @gumin.kwon
This issue is actually kind of complicated that I would like to know the exact info of below.
  1. The full uart log
  2. What Jetpack version is the one that you are sure it won’t hit issue? cat /etc/nv_tegra_release will show you the version during runtime. For example, what was the version of jp5.x ? 5.1.4? 5.1.3?
  3. how many boot iterations that you need to see the issue happened?
please share as much as you could provide. thanks.
  1. UART log: I’ll provide the full UART log within a few days. I need to figure
    out how to connect and communicate with the debug serial first, since the Orin
    NX is embedded inside a Unitree G1 robot.
  2. Previous JetPack version: I honestly don’t remember the exact version.
  3. Current state: Right now it almost always shows those errors when I power on,
    and it mostly fails to boot properly, together with the PCIe errors.
    Sometimes it does boot, but after a while ping works yet SSH does not connect.
    When I attach a monitor at that point, I see EXT4 filesystem errors such as:
    EXT4-fs error (device nvme0n1p1): dx_probe:822: inode…
    ext4_find_entry:1682: … iblok0
I feel that we need to know what items could you try on your side now because issue may not be just identified with just this current info.
For example, is it possible for you to get back your device from field and test it directly?
How was the development doing here? For example, I seldom heard a user directly told me they don’t remember what was the version they were using before. Isn’t this a mass production project that with a fixed BSP version?
Update on the UART log: I contacted Unitree, and they told me the UART/MB1 debug
log cannot be extracted on the G1 - the Orin NX is embedded in the robot and the
debug serial console is not accessible to end users. So unfortunately I can’t
provide the MB1/UART log.
Given that constraint, here is what I can do on my side, and I’d appreciate your
guidance:
  1. Repeated reboot test: I’ll measure how often the failure occurs (e.g. X out
    of 10 reboots) and report back.
  2. Physical re-seat: I had removed/reinserted the NVMe SSD after a partition
    expansion (external M.2 enclosure, per Unitree’s procedure). I’ll re-seat it
    firmly and re-run the reboot test to see if the failure rate changes.
  3. Any runtime diagnostics you suggest (I can run commands when it boots
    successfully).
What I have so far (full diagnosis attached):
  • NVMe (Unitree NX-2TB 2280): SMART clean (critical_warning 0, media_errors 0,
    percentage_used 0%).
  • ASPM already Disabled.
  • When it boots, NVMe (pcie@14160000, domain 0004) links up but at Gen3 (8GT/s),
    downgraded from Gen4 - LnkSta: “Speed 8GT/s (downgraded)”.
  • On failure: PCIe link doesn’t come up, “nvme probe failure status: -19”.
Since UART isn’t available, based on this data - does the Gen4->Gen3 downgrade
plus the intermittent link failure point to a PCIe signal-integrity / physical
connection issue? Is there a software-side test (e.g. forcing Gen3 in the device
tree, or a PCIe link diagnostic) I can run to narrow it down without UART?
g1_full_diagnosis.txt (90.6 KB)
Want to know
Are you able to reflash the board? The key items here are the UART log and whether board is able to get reflashed so that we could suggest the next step.
Is this Orin NX or Orin Nano?
Able to switch to other kind of NVMe?
The items you are talking about there does not really matter to current situation. I mean, what you could do seems to be limited. You should let Unitree to handle this situation. For example, let them join to discuss this.
